Dave notice the plural
Shazza i have found be honest with the police to the best of you knowledge, you are not a mechanic if that makes sense
for example my car sounds loud but a police officer asked me if it was too loud and i said to be honest i have no idea, as its never been tested so there was no point me making assumptions that it was too loud
  • Replies 188
so, this tsuuuu sound, what does it do? like, i see the original bov has more u's after it therefore its a longer kind of sound right?
dont mean to be a pain in the ass but im still waiting on a reply?
  • 4 weeks later...
Hey fellas,
Quick question...
What about, if I did the Cole can trick, drilled a small whole in the centre of the aluminium... Would that mean it would only flutter a small bit or when I rev the shot out of it???
As I was thinking then when I drive it easy it won't flutter?
Anyone know?
I suspect the flutter will just be a bit quieter than fully blocked, as you are letting a bit of air escape. Its the same as an adjustable BOV when you tighten it to only release a small amount of pressure.
I think Damo is being sarcastic, Jamie. If there is a small hole then only a little bit of air will flow out. For example on full throttle release (rev out) you should get flutter and bit of stockie wssssh and on partial throttle release (4000rpm gear change) you should get just the wsssssh sound and maybe the tiniest bit of flutter :D
Wicked! That's what I'm looking for!!!! So I can still be in stealth mode if I need to be... :)
You drive a skyline there is no such thing as stealth mode
Leave the car at home = stealth mode
Jamie, Steve is correct on this one mate. If you want to drive it in stealth mode then just return the car back to stock and that will be the only way to get about lol. I have an adjustable BOV if you wanna try it and see it this is what you are after.
Hey guys,
just completed the experiment of blocking off the bov however leaving some holes so that it can still be silent when you drive soft and flutter when you give it a bit...
So far it went well... It took a couple of goes to get the right amount of small holes into the aluminum so that it would be at the right pressure but it seemed to have worked...
I can see what you mean guys, when you say that I may need thicker aluminium due to the stress it will be under but we will see how it goes.
Thanks for the offer krishy, however I'm trying to stay away from after market bov due to that being one of the first things cops look for when they pop your hood... :(
Anyways... If people have been thinking of blocking their bov for the sound, maybe the way I have done it would be a good option... :)
cheers
Take it for a test drive and let us know how it sounds compared with before :thumbsup:
Took it for a run on PRIVATE PROPERTY (cough cough) and it sounded great... none of those stalling issues either...
As mentioned in above post, you can drive it softly with no flutter and if you want it to flutter just give it some stick!!!! :)
All is good...
(now to take it off so that i can drive on the public roads again withought being defected by the boys in blue....)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
