Dave notice the plural
Shazza i have found be honest with the police to the best of you knowledge, you are not a mechanic if that makes sense
for example my car sounds loud but a police officer asked me if it was too loud and i said to be honest i have no idea, as its never been tested so there was no point me making assumptions that it was too loud
  • Replies 188
so, this tsuuuu sound, what does it do? like, i see the original bov has more u's after it therefore its a longer kind of sound right?
dont mean to be a pain in the ass but im still waiting on a reply?
  • 4 weeks later...
Hey fellas,
Quick question...
What about, if I did the Cole can trick, drilled a small whole in the centre of the aluminium... Would that mean it would only flutter a small bit or when I rev the shot out of it???
As I was thinking then when I drive it easy it won't flutter?
Anyone know?
I suspect the flutter will just be a bit quieter than fully blocked, as you are letting a bit of air escape. Its the same as an adjustable BOV when you tighten it to only release a small amount of pressure.
I think Damo is being sarcastic, Jamie. If there is a small hole then only a little bit of air will flow out. For example on full throttle release (rev out) you should get flutter and bit of stockie wssssh and on partial throttle release (4000rpm gear change) you should get just the wsssssh sound and maybe the tiniest bit of flutter :D
Wicked! That's what I'm looking for!!!! So I can still be in stealth mode if I need to be... :)
You drive a skyline there is no such thing as stealth mode
Leave the car at home = stealth mode
Jamie, Steve is correct on this one mate. If you want to drive it in stealth mode then just return the car back to stock and that will be the only way to get about lol. I have an adjustable BOV if you wanna try it and see it this is what you are after.
Hey guys,
just completed the experiment of blocking off the bov however leaving some holes so that it can still be silent when you drive soft and flutter when you give it a bit...
So far it went well... It took a couple of goes to get the right amount of small holes into the aluminum so that it would be at the right pressure but it seemed to have worked...
I can see what you mean guys, when you say that I may need thicker aluminium due to the stress it will be under but we will see how it goes.
Thanks for the offer krishy, however I'm trying to stay away from after market bov due to that being one of the first things cops look for when they pop your hood... :(
Anyways... If people have been thinking of blocking their bov for the sound, maybe the way I have done it would be a good option... :)
cheers
Take it for a test drive and let us know how it sounds compared with before :thumbsup:
Took it for a run on PRIVATE PROPERTY (cough cough) and it sounded great... none of those stalling issues either...
As mentioned in above post, you can drive it softly with no flutter and if you want it to flutter just give it some stick!!!! :)
All is good...
(now to take it off so that i can drive on the public roads again withought being defected by the boys in blue....)
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
