I have tried the driving style called "Dorift" but on both occasions I have failed... :cry: ...and crashed my beloved skyline. Please help me to discover the true sensations that I am missing from not being able to master the sideways action....
I need to know what works for you guys, not what you have heard works but what actually has worked for you.
I am not talking about 1st gear around the corner, I want 2nd gear high RPM dorift please... :x
https://www.sau.com.au/forums/topic/241-me-wish-to-learn-the-way-of-the-dorift/
That was with 168rwkw now I have 206 I should be able to get 360o rather than just 180o :lol:
The pan was really different to anything I'd done before and I had no idea it would be soooo slippery, finally started to get the hang of it on the last corner of the night....lol
Well I have taken a few corners in my car lately, even though I dont want to , I just can't help myself with all this rain around. It's Just a case of getting the revs right and not over revving. It's really a case of getting it right, and obviously trying to learn your limits. Depends if you want to do it in the wet or dry (and fry the tyres). With all the wet around at the minute, it's hard not to get a little side ways. I find that in 2nd gear, at around 50 or 60, then slowly accelerating will really lighten up the arse end, pick the angle, of the corner, turn into the corner smoothly but hard, till she swings around, then grabbing the opposite angle and balancing between the inside and outside of the corner with your wheel. But you've got to try and keep your revs from jumping too high or else you'll be in all sorts of trouble. This is just in the wet, as I don't like buying tyres :lol: But I have to say, if your looking for nice long drifts, you gotta be smooth, don't jerk the throttle or the wheel.
Guest Fenn
look cam my first post just for you
this is how i have always done it......
depending on the power of your car you have to adjust to the angles
but as i come up to say a left hand corner i'll turn the wheel to the right and then quickly back to the left and take the corner (this gets a tail wipe going very good on hair pin corners)then it's just down to accelerator work.. then i'll start to correct early and hold it as to over correct and then just continue till the next corner (i can't do it in my skyline due to my irs and stuffed suspention but can do it in any car with a solid diff)
just that with the irs every time i go to change gear it squats and the ass just slides out anyway.
Drift accident #1
2 weeks after trading my 13sec starlet for the R32....
Coming up to a tight left hander with a friend parked opposite I slowed right down and into first! Then as I came to the corner for my first ever drift I hit the gas and it was all good but I kept it down too long and too far and I rotated all the way round and hit one of those nasty 30cm high gutters and ended up facing the wrong wayhalf on the gutter and half off
DAMAGE
Bent lower control arm
Bend CUSCO castor rod
Bent Upper control arm
1 buckled rim
1 torn open tyre
http://www.d-u-e-l.com/cams_ride.htm for pics
Drift accident #2
3 hours after fixing my car from #1
I had just spent 2 weeks fixing my last attempt when a friend came over to tell me of an awesome drift corner that he had found over the other side of town. So off we went, I told him that I was just going to take it easy as I didn't want to damage the car again but in the heat of the moment the car took over and .....
Came around a long sweeping corner in 2nd at about 65 the back went out when the car came on boost and it was looking good till the back tyre hit the outside gutter and flicked the car back the other way, I corrected but too much and the car flicked back around and up and over the gutter, sliding down the grass foot path and into a garden. While this doesn't sound bad it wasn't till the next day when I drove back with now 2 buckled rims when I discovered that I had removed a huge tree stump with my tyre, broken the concrete edge around the garden and missed the businesses gas main by 1 meter!
No damage to photograph sorry.
See I told you I need instruction, I must admit that I prefer straight line speed to drift but I will give anything ago.
When the car came to a stop my horn button fell out and the interior light poppe out, I sat stunned for a sec (it happens so fast) then just put my head on my steering wheel and wondered how much damage I'd done this time. More importantly, I realised that my friend in the passenger seat had trusted that I would make the right decission and NOT endanger his life without his consent, its different if he was in total agreement with me doing it but he may not have been. You never realise the consequences till it has happened.
The shiny bits :wink: Can you tell I'm a mechanic ... *NOT* :) May bay looks dirty, the piping is dull, and I wouldn't have a clue how to get it looking like yours.
BTW, how much did that jack in the picture set you back. I want to do work on my car but don't have a clue where to start :)
Here is a tip for everyone...some of you will know this but others will not.
I have worked on heaps of cars and the one thing I have found is that the job gets very easy with the right tools. Here is a list of tools to make the job easy.
Hydrolic jack $50
Car ramps $40 pair
Car stands $20 pair (use these when car is up for a while)
6mm-20mm socket set (JBS, Sidchrome etc) spend the bucks or its a waste of time get a couple of extensions and unni joint and half inch if possible.
Good pliers needle nose and normal
Good wire strippers
Good tape measure
Good set of philips and flat tip screw drivers
Good shifter (from REPCO with mm markings on it)
8-20mm spanners with open and ring ends
etc etc
Then buy a good tool box with draws and put it all in it.
This will all cost heaps but I can assure you that you will save nemerous times that by doing things your self.
As for the shiny bits. cover all electrical stuff with plastic bags and sealup the plug cover then use degreaser adn water to wash the entire engine bay, scrub with soft brush to release builtup crap and presto a nice clean engine bay. If you have an alloy item in the engine bay polish with autosole and generally remove everything , clean it and paint it or polish it or powdercoat it or what ever, it takes time and money but its worth the results.
Stay tuned for my section in mainenance with a more comprehensive list of tools for the home workshop.
TEIN 'v' WHITELINE
I really can't offer my opinion on this as I haven't been in a car with whiteline suspension. TEIN will cost you around $600 second hand for a set of 4 and are rock hard to most people find it too uncomfortable to drive in. I love it and they corner (stick not drift) really well with the tyre combo I have at the moment.
I got Falken Azenis on my front at the moment and they are certainly nice tyres.
Back to that list of tools you had listed before, where would you recommend I could buy them for around the prices you listed I need to start getting into my car :twisted: also in regards to taking things off and giving them a good clean (like piping etc) is there any way to know you wont screw it :?: My luck is that I'll take something off and not know how to put it back on, or oil will piss out of it, or worse :?
JimBo
Most shops like AutoBarn or supercheap auto or REPCO etc can sell you ramps, jacks and stands, the rest you should get froma hardware store. You may find the tools a bit cheaper at some specialty tool stores, just shop around.
Stuffing it up.
Have you got a digital camera? If so email me/us pics of the stuff you want to remove and we will tell you if you can or use a pic off my site of the engine bay and explain which bit you want to touch. Most items in the engine bay are easilly removable and will not cause too much stress, the main thing is to remember what order things come off in. Get a note pad and write down the order of removal then just reverse to re-attach. If you take out a bolt that is holding a bracket on, then screw that bolt into the hole once you remove the bracket that way you will not loose the bolt. Do not force a bolt if it seems stuck, spray some wd40 (hardware store) on rusted bolts and just bolts in general this way it will make it easy to remove them, tust me when I say you don't want to have to try and remove a broken bolt like I had to from my head when an exhaust manifold stud broke DAM. There is nothing like learning so don't be scared to pull stuff of and have a look, don't remove fuel lines or oil lines and any other line that may be under pressure.
Cool, I have a hardware house like 2 mins walk from my place. I'll have to try and find an AutoBarn though.
I'd really like to get my hands dirty and learn more about it so in the future working on the car will be second nature. I'd also like to confirm things that were on the auction report such as the 550 cc injectors, the turbo (not sure if it's aftermarket or not), the ECU (would you believe I don't have a single tool at my new place :) so removing it from it's bracket is a little hard :) )
I'm going to buy a digital camera once my redundancy comes through also, so pics shouldn't be too hard to get.
Hehe taking my rims off to replace with stock for my blue slip is the closest I've got to working on the car so far :roll: Would a pair of overalls and one of those flat rolling gizmo's you lay on be a good investment too ?
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
