I just purchased a Daniel Kent- Elite Racing bilstein suspension kit [basically the same as the SK one give or take].
I've presently got Tein HA's on and want to swap them out.
What I need to know, do the Tein top caps fit the Bilstein's with progressive king springs? OD 12.4cm, ID 10cm.
Someone said buy a set of std caps, but I'm nut sure what I have to buy or if they will fit?
I don't want to begin installing this stuff until I have the complete set up. I want to be able to fit and drive [inc. wheel alignment], not have it on blocks for days waiting for some part.
All help appreciated.
https://www.sau.com.au/forums/topic/241049-bilstein-suspension-kit/
No pillow ball tops on these units AFAIK. I can do a comparo, but it wouldn't be fair. The Teins are hard jap spec and jump and shudder/skip over every pothole/ripple. They are made for track work, not country NSW roads. On hotmix roads [like in Canberra and some Sydney] the car is very good, the teins work fine. But on lets say less refined surfaces, they are a PITA.
The Billies should be a fair bit softer and allow the tyre to stay in contact with the surface. I'm hoping that the swaybars will compensate for the loss of stiffness so overall I won't get any extra body roll, but time will tell.
yeah i know what you mean. like with my HA's theyre great on smooth roads but how often do we get to see them. I dont mind the stiffness but there are times when I drive around all day and the back starts getting sore. Your reason for swapping is probably the same as mine.
The black rubber bit at the top of the threaded spindle click spins, so I can adjust the ride stiffness, but the limiting factor is really the springs, I can't make it any softer than the spring strength/stiffness. I guess this means that I'm really only adjusting rebound dampening.
OK, I'll ask another way...................when you had your SydneyKid suspension kit fitted...........what tops were used?
agree with the above posts - when I replaced my Cusco coilovers with bilsteins I had to get the standard tops. SK provided all 4 for $250
I too am very interested to see how SK's set up stacks up against coilovers.
I couldnt live with a car that does not handle well. But these coilovers are giving me a serious case of SARS at the moment.
Very seriously thinking bout doing the change.
cris when you get the chance hit me up. i have bilsteins.
hijacking the thread again sorry but was it worth the swap?
The car now handles beautifully:
-doesn't skip over bumps
-much better traction especially out of corners, especially if it's bumpy
-more ground clearance - easily goes over parking blocks
-far more comfortable ride
-I no longer hit my head on the roof going over the bumps at the end of the main straight at Qld Raceway
-I dropped 1 second on my lap times at Qld Raceway
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
