  • Replies 47
  mad082 said:
yeah, or very watered down. or they got it for free and didn't pay the excise on it so are going to sell it without the excise on it.
thats's actually my boss' sister's petrol station, he said that little advertising/stunt made a $3k loss in that little period of time.
Even at a 3k loss it was a smart thing to do if their point was to also raise awareness and general turnover of stock. If you were to take the 3k and run something like a direct marketing campaign you would only get about 3 or 4 runs (depending on how big your target list is) and the "accepted" return on them is something like less than 2% if i remember correctly
Good on them
  Guilt-Toy said:
if i knew where they are then I would go there and pay full price.!
good on them
good on them indeed! i reckon its a fantastic idea - i don't think allot of people understand that not all petrol stations are directly owned by the big companies. there like the MacDonald's franchises that are owned by family's - if we all decide to go to the family owned stations and not buy from the Cole's and woolys stations, then the coles and woolys stations will be forced to put their prices down in order to attract the majority again...and they can afford to do this so they wont hesitate.....
either that or it was a well planned idea, get the cheap petrol out to everyone then when everyone else hears the que gets longer and bam lets put the price back up and enjoy all the money coming in...hahaha
doubt thats how it works but would be good:P
even if they do the price cut is only on regular afaik.
and I can't believe people are willing to line up for 2 hours just to save $20 or so. they are effectively earning $10 an hour for sitting in their car. not a good return if you ask me. I'd rather go up the road and fill up in 5 minutes, spend and extra $20 and spend my time doing something else. i guess it's a moot point for us anyway since we all need 98RON fuel for most of our cars.
Legends! - i only live 5 mins from there so im filling up there from now on dont care what the price is...aslong as they have Premium or Ultimate even if it is full price..... to bad its only THAT BP thats doing it.....im not supporting them because i will save 20 buks if i go and fill up there but because of the fact that they are taking money out of there own pocket to help everyone
+11ty....
lulz - you said moot.
yeah but thats not the point they are making and the people that are lining up are probably doing it to support them not just to save the cash.
They didn't lose any money doing it this time, channel 9 gave them $5k to drop the price this morning.
Thats awsome, there getting heaps of support.... volunteers with the bbq....free eggs from the farmers and now free news coverage as well as the 5k....Goooo BP!
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
