Hi all i know this has probably been answered somewhere on here but couldnt find it...
Have these coilpacks been made yet?? If so, where can i buy them from (either locally here in SA, or on the net, i have checked kudos motorsports with no luck).
If these haven't been made yet, where can i buy Splitfires for my car from? (once again net/SA).
Cheers
Dan
https://www.sau.com.au/forums/topic/241075-twinspark-for-1998-s2-r33-gts-t/
Ok i'll try again...I meant to say superspark.
As in, the only superspark coil packs i can find are for PRE-1995 R33 GTS-t's only.
Is there a version for POST-1995 models yet? I know there was previously discussion about the (hopefully) imminent arrival of these packs
Cheers
Although they claim to be the only ones to increase spark over and above the OEM one
So basically like having a HKS Twin power + Splitfires but all in the one neat package <- Can anyone back this up?
I would prefer a green one in my pocket and go the JJR's though :rant:
For $500, there is no way its the same as a HKS DLI + Splitfires(or stock coils)
You need replacement coils either way sometimes, and the DLI is additional cost ontop.
I think Splitfires 'claim' it too, but it was tested by two people on here a while ago, and it was virtually nothing different
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
