hi all,
i have a gt3076r with a internal wastegate
is it possible to weld the internal wastegate shut and use a external wastegate?
would that work?
would there be any benefits from this?
im just curious, i just want to get the right information because ive been told many different things
thanks
chris
https://www.sau.com.au/forums/topic/241085-internal-wastegate-question/
Well you'll only have benefits if the internal wastegate doesnt work correctly.
If its a proper Garrett housing, then it wont have problems and therefore you do not need one.
It will work, but i dont see the point. But the external gated version if you want it (they are cheaper too for just the turbo as the rear housing has no gate setup on it etc)
But he is not going to get any benefits if the internal gate is working perfectly fine
If the turbo is new just take it back to the store and swap it for an external housing then go buy a waste gate
I am running a GT3582 with internal gate and no problems 15psi / 260rwkw
i agree dano
im also running a 3582r-iw at 330 rwkw's at 24 psi with no boost issues
but if the man's convinced on chaning for some reason, dont weld the standard one just change housings.
i agree dano
Nice, I am hoping to push it up to around 20psi next tune to see what it does, what size rear you running?
At the end of the day if I had to go external with my setup I will just weld the gate cause the price of housings from garrett are nuts considering I probably wouldn't be able the sell the IW housing too easily
At this stage I honestly dont see the internal gate being a problem...
.82 and mines a auto rb25
the be 100% honest
the only reason why the though of welding the internal gate shut was because i want a top mount manifold
and every single damn manifold i have come across all are made for external wastegates
so the thought of welding the internal gate shut popped up in my head... :P
the be 100% honest
so the thought of welding the internal gate shut popped up in my head... :blink:
you can still run it high mount, Mine is!
Rather than bastardize your turbo just weld a bit of plate over the gate pipe - that's exactly what I have done
yeah of course it works!
Will cost you next to nothing if you have the manifold off the car...
Then if one day you feel the need to have an external gate and screamer its just a matter of grinding off the plate and putting an external on.
make a plate and bolt it to the manifold, use locktight and use some high temp goo around it to make sure it seals properly.
that way you don thave to take the manifold off if you change your mind
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
