What days do u want to cruise??
Guest RedLineGTR
Just starting a poll to see what days would suit most people for a organised cruise. A couple of options are avaliable, but if you are avaliable to cruise on more than 2 days please post it up so we can figure out which days would suit people better.
Cheers Rob :burnout:
https://www.sau.com.au/forums/topic/24112-what-days-do-u-want-to-cruise/
Guest RedLineGTR
well just getting some ideas...but yah if the cruise is organised in advance then more people would be able to make some arrangement to get out of work etc..a good example of Ash's cruise...well planned and was organised in advanced with showed a good turnout..Rob
  • 3 weeks later...
