Hey, I'm reading through the importing document on DOTAR, and I'm confused by this particular sentence. I don't know whether it's referring to Vistors coming into Aus with no form of PR, citizenship or Australians with citizenship visiting another country with a temporary visa. I'll be heading off to Japan to study abroad for a whole year and want to bring a Supra back with me. I've bolded the section in question.
5.5. Personal Imports – Part 10 on Application Form
The following are not eligible to import a vehicle under the personal import scheme.
visitors temporary residents foreign diplomatic personnel companies corporations
To be eligible for a personal import the following criteria must be satisfied:
a. the vehicle has been owned and used by the applicant for a continuous period of at least 12
months (3 months where ownership and use of the vehicle commenced before 8 May 2000);
b. at the time the vehicle is imported, the applicant is:
i. an Australian citizen or an Australian permanent resident; or
ii. a person who has applied to become an Australian citizen or an Australian
permanent resident;
c. the applicant is of an age that entitles him or her to hold a licence or a permit to drive a road
vehicle of that type;
d. the applicant undertakes to comply with any requirements as to road safety that are imposed
in respect of the vehicle by the Administrator; and
e. the applicant has not imported a road vehicle owned by him/her within the year ending on the
day on which the vehicle in respect of which the application is made is landed in Australia. If
an applicant has imported a vehicle under any other provisions in that time, approval will not
be granted.
https://www.sau.com.au/forums/topic/241150-personal-import-help/
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
