Need A New Clutch Asap!!! Where's A Good Place 2 Buy 1???
Clutch is pretty much gone, does any1 know where's a good place to get 1 from around the gold coast? on the cruise tonight some1 mentioned a place called "ABS" are they good? i have to pay rego next week as well so i need to find 1 for a really good price... PLEASE HELP !!!
ABS BRAke and CLutch - they will beat any realistic verbal price u give them, even if its serperate clutch cost and labor cost. Well I did and they beat it. Mine cost $540 in total for DAikien Exedy Heavy Duty installed - with the works like gearbox oil, fly wheel spin (i think tats it) etc. etc. there's a previous thread regarding CLUTCH. check it out :(
G/L
Getting my new clutch fitted today, got a Daiken Excedy heavy duty too. Got it thru Nicks - good deal. The mechanic who fitted just rang and said 'it feels like a bloody strong clutch, where did u get it from?' Cant wait to knock off work early and go pick it up.
Originally posted by 4 Doorz
Try Nicks Performance Clutches at Archerfield/Coopers Plains - good clutches
I'll second this. Speak to Doug. He's done the clutch in the skyline (organic clutch with a 3000pound pressure plate. Best. Clutch. Ever. and he also did the clutch in brutis. It's a 1650pound cable clutch) I can't drive Brutis beacuse the clutch is too damn hard.
I think the skyline clutch cost about $300.. not very expensive at all.
My clutch is meant to be rated at around 600hp. So it supports my 50hp quite nicely :bahaha:
yeah its a hard spring pedal but its not hard like it used to be, i really want 1 like i had (nissan 1) or anything else with a really hard pedal, im calling daiken on monday and having a winge cause the description states it will be harder than before instead its toooo soft for me, cant stand it!!!
most HD clutches that are sold are remanufactured units that are modified to give stronger clamping pressures. Thats why there is such a price difference between ones sold as HD and the proper racing clutch kits from Exedy, nismo, ORC, OS. Nothing wrong with the HD ones just thought you guys should be aware of what u'r buying.
I recommend Nicks clutch aswell as Jim Berry at RACE clutch engineering. If you want to know everything there is to know about clutches go have a chat to Jim and be sure to allow atleast an hour :)
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
