hey guys,,, plz help me.... i have just installed injectors and the electrical plug with them on the loom... new spark plugs and cooler joins and clamps... i disconnected the negative terminal of the battery,, as i brought it off it sparked a little but nothin serious... but when i come very close to disconnecting it it started beeping the whole car... lights and brake lights were flashing, dashlights, and the dash was beep beep beep... i disconnected it....now everything is back togther but the car does that beeping things once i re connect it.... and when i put the keys in and turn to a/c it still flashes and now wont start!!!!... not even turn over!!!.... its like a dead battery but it isnt dead!!!... i cant stop all the beeping unless i disconnect the battery again!!!!
HELP!!!!
i have a microtech lt-12 ecu if that help
thanks guys
https://www.sau.com.au/forums/topic/241271-help-r33-wont-tick-ova/
sounds like an alarm problem actually.
If it does abbroad minded femaleely nothing, like not even attempt to kick over, then its your immobilizer.
try checking around if you didnt know you had one. Most skylines do these days as its very hard to get insurance without one
