Hey guys,
For those with R33 gtst's, and harnessess - where have you bolted the shoulder straps to in the rear of the car?
I have used the bolt holes on the backseat from the back right hand seat, (where the existing seat belts would go if the backseat was there) however the angle of the harness is around 45 degrees...looking at the cams manual, it says the acceptable range is no more than 40 degrees...
So what have others done?
Is it enforced strongly also?
Pics would be handy if ya have them :cheers:
Thanks guys,
Chris
https://www.sau.com.au/forums/topic/241272-r33-harness-and-cams-rules/
Chris its rarely enforced strictly in a road car.
However one option is a purpose made bar that goes from tower to tower across the rear parcel shelf. I have made a fair few of them for R33's and they work fine.
Edited by Risking
Chris someone (and I can't for the life of me remember who) make a parcel shelf strut brace. If you can find out who makes them great or go with Brads idea. The rear seat belt points suck,,,in a roll-over your shoulders are subject to way to much force.
Just keep in mind cams rules are minimum requirements,,,always try to do better.
Neil.
Cusco do parcel shelf bars for the R33 from memory.
There okay and you can wrap a harness around them, but not really strong enough in my opinion.
Ill try and dig up some photos of the last one I made but basicly it was 38mmOD 2.5 wall thickness CDS (same as minimum spec cage material) It had decent sized mounts and the harness mounts were the usual eyelets with welded in thread bosses.
Also did one for an RX7 not to long ago (actually you'd know the owner Chris, Craig Baker)
Nah Brad It wasn't the Cusco one,,,I bought one off Johnny at UAS some years ago that was good quality steel that would do the job.
I actually gave it back to him thinking it was wrong. Strupid me.
Really the only way to secure the shoulder belts properly would have to be a half or full cage.
But after saying that the series 2 GTS-T's have mounting points for a strut brace in the boot which I use. Cutting the rear fire wall to run belts through there would be another way.
The Skylines parcel shelf is no way strong enough in my opinion,,,but the strut towers would be.
Neil.
Hey Chris,
My harness is mounted in the back seat belt bolt holes also and i have roughly worked mine out to be 33 deg below horizontal or 57 if you are measuring from the vertical postion? When i fitted mine i never checked cams i followed the instalation guide that cam with mine ( it is a Takata harness ). I can post up pictures if you cant remember what it looks like or you are more than welcome to drop in on your way home on Sat and have a look.
I have attached the page out of the manual for you. Would mine pass?
harnessguide.tiff
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
