  • Replies 41
put the pod in the airbox. cut a hole in the bottom of airbox and have a pipe (preferably black) from pod, through hole to compressor.
so u mean having a pipe under it for air? what if you just leave a hole with no pipe?
keep the airbox in place and the piping that feeds it. get rid of the piping from the airbox to the compressor. cut a hole in the bottom of the airbox. put the pod in the airbox. a black pipe from the pod down through the hole in the bottom of the airbox to the compressor.
if you have no pipe then there will be no air going through the pod and your compressor will be ingesting unfiltered air...
^^ not sure what you're talking about. if he has a pod in place, the air wont be unfiltered. but yes. you will benefit from a cold air feed. and you certainly dont have to mess with the compressor side of things.
have a look through the tutorials section. theres a few threads in there about cold air intakes / boxes
here's one of them
http://www.skylinesaustralia.com/forums/Cai-Box-t208789.html
Edited by Munkyb0y
Simply put - No chance.
Cops and EPA aren't stupid, they know what the factory airbox looks like, you'll never get something made that looks like it for a reasonable amount of money. You'll get pinned everytime for the 1x intake mod rule
ahhh k, i just havent seen the stock air boxes thats why im not sure with the pipe and stuff leading out of it. u noe how much it would be to buy a 2nd hand air box
yeah but he'll get done for the airbox or the front mount either way.....
best bet is put orginal air box,,,, just jap stealth front mount and paint it all black
there in the trader zone.....
pod with no pipe pod will fall out hole. pipe needs pod on one end inside standard airbox and the other end attached to the compressor inlet. the pod will be concealed inside the airbox.
yeah dats the type of frount mount im planning to get. bt my question was can i put a pod in a stock airbox so it looks lyk stok air filter
question remains...
Why keep the pod at all if your going to put it inside a chopped airbox?
If its for sound, forget that, and it'll be boxed up so it wont sound the same
If for performance, forget that, a good airbox with decent panel filter will beat a pod without proper CAI everyday
:cheers:
would it possible to keep the pod attached to the afm and sumhow get box to sit over it without acatly having to have the box connected to the afm
Cold Airbox Assembly.
Or just upgrade your panel filter to a high flow one
have you looked in your engine bay?
you got buckleys unless you relocate the filter to near where the stock I/C was in the front bar
still illegal :D
What do you guys think if I get that stealth just jap cooler paint it blak and put blak mesh in the front bar in the opening. I rekon that would be prety hard to see especialy at night and also considering the cooler uses the stock pipes. I dont want to lose my pod cause to me its not a turbo unless i dont have that sucking noise and flutter. what u guys think?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
