  • Replies 41
put the pod in the airbox. cut a hole in the bottom of airbox and have a pipe (preferably black) from pod, through hole to compressor.
so u mean having a pipe under it for air? what if you just leave a hole with no pipe?
keep the airbox in place and the piping that feeds it. get rid of the piping from the airbox to the compressor. cut a hole in the bottom of the airbox. put the pod in the airbox. a black pipe from the pod down through the hole in the bottom of the airbox to the compressor.
if you have no pipe then there will be no air going through the pod and your compressor will be ingesting unfiltered air...
^^ not sure what you're talking about. if he has a pod in place, the air wont be unfiltered. but yes. you will benefit from a cold air feed. and you certainly dont have to mess with the compressor side of things.
have a look through the tutorials section. theres a few threads in there about cold air intakes / boxes
here's one of them
http://www.skylinesaustralia.com/forums/Cai-Box-t208789.html
Edited by Munkyb0y
Simply put - No chance.
Cops and EPA aren't stupid, they know what the factory airbox looks like, you'll never get something made that looks like it for a reasonable amount of money. You'll get pinned everytime for the 1x intake mod rule
ahhh k, i just havent seen the stock air boxes thats why im not sure with the pipe and stuff leading out of it. u noe how much it would be to buy a 2nd hand air box
yeah but he'll get done for the airbox or the front mount either way.....
best bet is put orginal air box,,,, just jap stealth front mount and paint it all black
there in the trader zone.....
pod with no pipe pod will fall out hole. pipe needs pod on one end inside standard airbox and the other end attached to the compressor inlet. the pod will be concealed inside the airbox.
yeah dats the type of frount mount im planning to get. bt my question was can i put a pod in a stock airbox so it looks lyk stok air filter
question remains...
Why keep the pod at all if your going to put it inside a chopped airbox?
If its for sound, forget that, and it'll be boxed up so it wont sound the same
If for performance, forget that, a good airbox with decent panel filter will beat a pod without proper CAI everyday
:cheers:
would it possible to keep the pod attached to the afm and sumhow get box to sit over it without acatly having to have the box connected to the afm
Cold Airbox Assembly.
Or just upgrade your panel filter to a high flow one
have you looked in your engine bay?
you got buckleys unless you relocate the filter to near where the stock I/C was in the front bar
still illegal :D
What do you guys think if I get that stealth just jap cooler paint it blak and put blak mesh in the front bar in the opening. I rekon that would be prety hard to see especialy at night and also considering the cooler uses the stock pipes. I dont want to lose my pod cause to me its not a turbo unless i dont have that sucking noise and flutter. what u guys think?
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.   As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.    I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.   Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.       BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
    • Yeah, I wasn't giving two f**ks for the ring running around the bore. I was looking at the vertical scratches running up and down across the hatch marks.
