Just came across these and am very likely buying them. 18 x 10 and they are fitted to this R32 GTR with no guard rolling or camber. So it would seem that the success of fitting this size is down to the car set up and the rim, especially the offset. So it can be done.
I'm still gunna get me some TE37s......(drool).
the BBS are good, but they don't have the most caliper clearance out there. make sure they will fit over big brakes if you are running APs with 355mm rotors. I have BBS LMs as road wheels on my grey 32 and they only just clear R34 brembos I have on there. for track I use Weds TC-05s or my Enkei NT03s. both forged, light and good brake clearance.
Yeah, thanks BB. I've measured from the face of the rotor to the inside of the spokes and we've got about 72mm, and 65 is a generous dimension for this caliper (so I'm told). The car I did this on, was running Alcons on a 355 or 365mm rotor, so hopefully OK.
Just to ensure I'm not guilty of spreading misinformation, I've just visited this car and the guards are lipped, but no camber. I'll take my car with no lipping to the rims on Monday and report back about how they fit. Seems 10" is getting on the wide side but with some jiggling they can be made to fit. Sorry for the bum steer y'all.
Yup, 9" BBS LM's with a +20 offset = no problems clearing Alcon 6 piston calipers with 365 rotor
:/ that shut me up! I have the 9inch +20 too and they were quite close even on my old stock 32 set-up, but I guess the alcons don't protrude much more than stockies. carry on. :)
FYI this car has R34 Brembos and clear well. My brake guy said the AP CP5555 caliper has a similar lateral dimension so same should be true for them too.
I've trial fitted these BBS LM 18 x 10 and to me they don't fit. Just a smidge too wide. With my suspension settings I suspect they might have cleared the guards under compression (though hard to tell as it was car park driven only), but they sat a poofteenth proud of the rear guard and just looked too big. Full lock either direction was fine too. A real pity as these are beautiful rims. I guess as they fit the purple 32 they can be made to fit with some work. Purple GTR is for sale FYI.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
