Hi guys,
Over the last few days I've been busy mounting my tweeters to the plastic sail piece behind the side mirrors.
I decided to write a how to on this to help others that may want to do the same.
Note that you can use this method to mount speakers on your A pillars too.
Anyway here it is, I originally posted it up on another forum but since my car is a Skyline I thought I would post it here.
Ok had some time spare today so I thought I would make a costum mount for the tweeters.
Again I will write it up as a how to just in case you guys want to do the same.
The location was pretty hard to decide, it was either the sail trim or the A pillar. I spent an hour with the using BluTac and tweeter location / angle before deciding with the sail trim. A second person would come in handy to do this, so you dont have to go back and foward.
Note: YOu can do the same process to mount the tweeters in your A pillars
Imaging is a big deal for me, so took ages to the angle just right with the BluTac, and once getting the ideal position I hot glued it in place. Once the hot glue cools and bonds, make sure that you add more glue to make sure that the bond is strong enough to stretch fabric over it without breaking.
Note: Before you start gluing make sure that you roughen up the surface with coarse sand paper and then use Prepsol to clean the surface.
Once the hot glue cools down you then cut a piece of elastic fabric to cover the whole piece. I got this fabric from Lindcraft for $3.99 per meter. Use some super glue and start with the tight corners. I put some on the plastic and used a flat head screw driver to push it into the corners. Do small bits at a time, and practice stretching the fabric over before using glue.
It should look like this.
Tomorrow I will simply use fibre glass resin to harden and bond the fabric to to the plastic.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/
Now is the fun part :D
You will need these products and tools to complete this stage.
Resin
Activator (Hardener)
Latex gloves
Mixing container
Cheap paint brushes (discard when finished)
You then simply pour the resin in the container and then drop some activator into it. Ratio should be 1/100 but it was a cold day today so I mixed in about 5% so it will dry faster.
Use your brush and mixed the resin up with the hardener, making sure that you have mixed it well. Apply the resin with the brush, making sure that you have saturated the fabric and for it to seep through to bond with the plastic. Try not get too much on the back of the sail, cause you will need to trim if off later. Also dont apply any to the area where the tweeter mounts, this will make it easier to trim off.
Now just waiting for it to dry.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4212454
Ok a few more steps.
I was a lil impatient with the drying so I stuck it in the oven at the lowest temp setting. If you do this becarefull not to have it too hot cause the hot glue will melt. It took about 30mins for mine to go hard.
I then trimmed all the fabric off and then used a Dremel to clean the rest of the edges. Sanded it back to get rid of all the lumpy bits
Ok at this stage you can choose to take the easy way out and just cover it up with vinyl or prep for painting. I opted for a carbon fiber finish, a lil bit more work but well worth me thinks.
So the first step is masking off the area you want to use in the CF, this is important to stop fraying and pulling of the strands.
CF requires a diff resin then FG, the resin needs to be clear so you can show off that nice weave. I have chosen to use surf board resin as it's easier to sand back and polish afterwards.
The laying of the CF was pretty hard as it was all one sheet. Trick here is to put resin on the sail first, lay the CF on and then apply resin on top. You kinda have to wait till the resin is tacky so it can stick to the sail. then lay heaps of coats on so you can sand it with out going through later on.
Will have to wait 24hrs now for it to dry, no hurrying up this process unfortunately.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4212457
Did a little bit more today.
Trimmed all the excess CF off with a Dremel. Note if you are doing this I would suggest you get yourself one, even a cheap rotary tool will do, or else it's virtually impossible to do this. Try and not cut into any plastic though.
As you can see the CF dried a bit dull and lumpy. The next steps will be to sand it down to a smooth surface and then polishing it. I should be able to do this tomorrow after work.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4212459
I was bored so I grabbed the wet and dry paper and started sanding it back.
This was done with 800 then finished with 1200 grit wet rubbing. I meant to start on 600 then 800 the 1200 but I didn't pick up the 600 at the shop by mistake.
Anyway this is one step closer to getting finished, I'll throw some polish on it and buff it up tomorrow to a glass finish.
Here's what it looks like rubbed back, also known as the dry carbon look.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4212461
Ok the final stage.
This was actually so simple, I thought I would have to buff it with my Dremel, but instead I put on some car polish and buffed it like I would a car and hey presto done !!!!
Took about 5 mins each sail to do lol
Here are some pics of them
Hope this helped you guys that are wanting to do something similar.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4214452
  • 2 months later...
  • 1 month later...
shit man i just swapped my x type splits today from the front to back DDLinear in the back now and had no idea wat to do wit the tweeter, thought i was going to have to cut the door trim, your post has saved the life of my door trims, legend.
Also do u know a dude named Lloydstrom, he's got a calibra too and i remember he had a mate wit a 32 GTR that got painted at Louie's workshop? ring any bells?
anyway cheers dude
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4421335
  • 1 month later...
can you remove the tweeter if you need to or you need to break everthing to remove it!?
Unfortunately the base of the tweeter is molded into the sail, but the tweeters can just twist out.
anyway cheers dude
Yep known him for ages, worked on his Calibra at Louie's workshop too.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4488373
  • 3 months later...
  • 4 months later...
FYI,they come out better if you lay a smaller # GSM thickness carbon fibre cloth it wraps around the part without pulling on the weave so much(looks similar to other car dash trims make out of carbon, and if you dont have black plastic parts they wont come out the same at all. the background will show the original colour, and you may need "wax in styrene" if you want it to dry hard ?
and they also make a few types (speeds of hardener depending on the heat and humidity)
using the wrong stuff can melt the dash parts, distort them beyond repair, and worse case it can catch fire from the chemical reactions to harden ,plus if you buy the cheap stuff it stinks to like hell...lol
or never dry if the weather is too cool out. to hot it can blister as well.
Oh and they do make a at least 50 different types of cloths,weaves, thickness and there area a few tricks to do it right the first time and keep your sanity
not to stop the DIY people .....but inform you it doesnt always go so smoothe , and basic cloth cost is 5 times fiberglass cost in general in RAW form.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4962416
you should do a few sets and sell them, i know i'd buy some :)
i'd just f**k them up haha
maybe in the future,,,which is why I warned people about it in advance..lol
carbon is a fussy bastard to work with sometimes to look nice.
https://www.sau.com.au/forums/topic/241312-molded-tweeters/#findComment-4983463
  • 4 months later...
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
