Had my car back on the Dyno today due to some issues I was having and thought id post the graph.
It was done on a DynaPac Hub Dyno.. Its interesting looking at other peoples results the difference in curves from a roller to hub dyno.
Edited by SLYDA
https://www.sau.com.au/forums/topic/241318-power-run-on-my-r33-done-today/
140rwkw @ 4000rpm... jebus, thats fairly unresponsive, especially for a .68
You should be seeing a show at least 500rpm sooner, if not sooner than that again. Its nearly 4500rpm before its working and my GT30 (.86) was on sooner than that. Also the hump around 5250 shouldn't be there, tune might need attention perhaps
Do you have the right actuator/running high enough off the actuator?
And why doesn't the graph go to at least 7000rpm?
Was this before or after your issues were fixed? (what was the problem?)
Peak power is good, about what you'd expect, i wanna see 7k though as you can see its still climbing ;)
Possibly, have you pulled em out and checked for visual cracks etc?
Actually, just thinking, on a HUB dyno... that means the power is even lower than what "rwkw" is based on.
So its less than 140rwkw @ 4000rpm...
You really have a problem dude, got a graph with the boost plot?
Problems getting worse and worse... it was missing up in the higer rev range on the dyno on the run, previous runs it had more power and didnt have that flatspot between 5000 and 5750RPM , now i cant take it over 4000RPM... Im guessing the coils are dead the timing was increased a few degree's further on that retune too. Ive done the silicon trick which didnt do a thing and plugs are gapped at 0.8. :).. Couldnt see any cracks or anything, they had previously been wrapped in electrical tape when i was first having issues years ago with the 1.1mm gap.
I can get a set of SuperSparks or whatever there called from Autobarn tommorow for $499 or something or splitfires off ebay for around $635 what does everyone think?
Edited by SLYDA
Peak power is good, about what you'd expect, i wanna see 7k though as you can see its still climbing :)
It was a full HKS Bolt on kit came with everything including the 10PSI actuator. The graph doesnt go to 7000RPM as they didnt wanna take a stock motor that far with the issues i was having. The issues i was having was the car idling like CRAP, it missing all through the rev range and high knock levels on different situations and what seemed to be ignition breakdown. And i agree about the boost comming on 500RPM too late, im looking at a printout off another car with a 3037 and it hits 17PSI at 3750RPM what would cause this?
Fuel pressure isnt an issue as its at 45PSI and I have 740cc Nismo Injectors mabee i have a manifold to turbo leak?
I think you need to set the actuator/boost control a lot better...
Hence getting a Boost/PSI graph :)
What are you using for boost control? I assume your running a EBC or Bleed Valve? as you have more than 10psi (actuator)
For now, it sounds like you need to set the actuator closer to the target boost (say 15psi), and then config your boost control/actuator from there
It's always better to get as close as you can off the actuator.
Obviously fix the other issues you have first. You wont know the car when its running boost 1500rpm sooner. It'll tear your nuts off and rev it upto 7000rpm :(
Hence getting a Boost/PSI graph :down:
Im actually using the Apexi Power FC Boost Control Kit and i actually do have a boost vs HP graph
Settings are 1.3Bar Boost 67 for duty i think and then it had another number i couldnt change 200? but then i taped the duty up and down and it changed to 255? I gapped my plugs down to 0.6mm and thats got rid of a fair bit of the missfire issue but its still doing it, ive already purchased today over ebay a new set of Splitfires $635.
The only thing i think may be dodgy is the manifold to turbo gasket i used a thick one not the thin metal one would it be worth changing it? its going to be a massiveeee pain in the ass job to do, but i want my car running right.
Also my brakes are pissing me off as they keep squeeling, ive replaced the rotors, have TRW pads i think they are, have had the calipers overhauled but it seems to just want to keep glazing the pads! and to make things even better i think ive blown the ground track in the Pioneer DVD player and now im gettin engine noise through my stereo :ninja:..
16psi @ 5000pm... there's your problem.
Poorly setup boost control, simply put, whoever config'd/installed the AVC-R. Didnt do a good job, rather poor infact...
It doesnt help that they aren't one of the better EBC's either. Hard to setup, single solenoid etc etc
I reccomend this.
Get a decent actuator. Set it up to run 17psi, then see if you can tweak the AVC-R to bring on boost any earlier (incase the actuator opens slightly early).
If you get no change, sell the AVC-R, no use for it if you cant get it any better :ninja:
Wont be gasket related unless its not sealing, and thats easy to tell by looking at it and seeing if it had buildup around the area.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
