ey guys
once again im posting up cos im lost for ideas
got home today n had my lights on and noticed rears werent working then also my dash wasnt working.
ive checked my fuses, bulbs !
not sure what else i can check any ideas?
btw its an R32 gtst
ohh and to be a pain i installed a greddy profec B spec 2 boost controller in on sat
and i dun think its boosting rite it doesnt feel like 12 psi
and at high rpm i can hear a rattle me n my mate reckon its the solenoid....
any1 got any ideas on wat it could be ?
cheers boys
not so woried bout e boost i need the lights fixed asap :D
Check the ground wire that you taped into with the eboost. Generally i have found this problem has been because people have taped into the illumanation wire by mistake, which acts like a ground wire untill you turn on the lights then it has a positive power.
Hope this makes sense.
