hey guys, havin a slight issue with the 34... gets hot really easy... ill put it as easily as i can and maybe someone knows what im on about... i drive the car for about half an hour and the oil temp goes up to half way... usually it sits on quarter... after this half hour, if i let the car idle, like run into the shop with the car still on, the water temp goes right up to almost full... drive again and it comes back down... though the oil temp stays at half way... any idea's... only started happening about 200kms ago...
Cheers
Guy
https://www.sau.com.au/forums/topic/241325-water-pump/
water pump will also start to leak a bit when its going out.
Heres a tip:
give the shaft of the fan a shake a bit, if its loose then the water pump is on its way out... if its tight and there isnt any play then its still ok.
other options is like what karl said.. the coolant
and possibly blocked radiator?
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4212679
I'm no mechanic but I have had a similar issue which ended up been a blocked heater core. I have been told that if there aren't any visual leaks to check the radiator and see if it is loosing coolant. If you aren't loosing coolant and there aren't any visual leaks you may have an internal leak somewhere or a blockage, get a mechanic to take a look you may have a blocked heater core or radiator.
Edited by Nimmo
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4213088
  • 2 months later...
ok well i have spent the money on the 100k service, plus go tthem to replace the idler pulley and tensioner....still overheats, not as bad but still does, as soon as i stab it, up it goes, if i drive it like miss daisy, still goes over half and the oil temp still goes over half also... getting a little worried here guys,
DOES ANYONE KNOW WTF IS GOIN ON HERE??
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4340029
Have you checked the thermostat and radiator? First things to check when a car over heats. Take the radiator out and send it to Natrad for cleaning, then replace the thermostat. If it still overheats then there is a more serious problem.
Hasn't blown a head gasket has it?
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4340080
well i figured NISSAN would check these things... they went over the whole car and all they said i needed now was rear pads, rear discs skimmed and air con pulley... was almost ceased or something...
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4340103
Check this part of your radiator hose fitting.
May not be the entire solution to your problems but it will help... See if it looks like mine (I doubt coz mine is custom fabricated stainless steel thanks to the old man) or corroded and broken away. After changing mine to a new one I noticed about 20 degrees difference in temps... the corroded metals were mixing in the coolant making it all dirty and brown..
If it's dirty, replace the fitting and flush your radiator out etc.
Edited by Magic
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4340153
i have a feeling its the thermostat either not opening or shutting right.
My thermostat was stuck (replaced it and the water pump a couple of months ago), it would take AGES to warm up and then climb reasonably quickly once it was over 80deg (as the thermostat wasn't opening fully) but I don't think it climbed as quickly as this blokes' seems to be.. the only time my temps have ever climbed that quickly when giving it a "stab" was when I split a heater hose.
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4340348
we definitely went over the whole car and your water pump was still fine, not grinding or anything, your radiator is still ok and it wasnt blocked, we flushed your radiator just incase. the mechanic who worked on your car is one of the best we have who worked on these imports regularly. the thermostat is what you should replace as it is one of the main parts of the cooling system and ive got trade price on that for you. about your air con pulley, the mechanic said that your pulley was making lots of noise and its rough as well which usually means that it is goin to cease sooner or later and imagine if the crankshaft pulley or harmonic balancer is trying to move the ceased pulley; thats why he didnt put the air con belt on. apparently, my parts guys said that he sold a lot of these pulleys to skyline owners. and did you say your car gets hot when standing still? if so then your thermofans might be out because when standing still, theres no airflow to the radiator and usually when the coolant reaches a certain temp, the fan will come on and control the temperature but when moving, theres airflow so it cools down the coolant as it passes through the radiator. if the fans are working but only at a stage where its getting too hot, then somethings wrong with the sensors.
Edited by R33_NICK
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4340821
Are you getting confused about Oil Temp and Oil Pressure? I'm pretty sure your car should only have a Oil Pressure gauge and that is meant to raise according to the RPM of the engine.
When driving normally my Oil Pressure sits between 1/4 and 1/2 but if I gun it it will go up more probably as high as 3/4. So are you looking at this gauge or do you actually have an aftermarket oil temp gauge?
But for the water temp; check your fan is working.
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4342677
no the 34 has the three guages in the centre, volt meter, oil temp, and boost... so yeah i know its definatly the temp and it sits on about 110 degree.... As for the fan, i know the hub is screwed, i can hold it with one finger while the car is running, even when i rev it...
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4342795
fan clutch hub?? any thoughts on this? i can hold it with one finger while its running, would this be the cause of the overheating??
hey guy holding the fan with one finger is a bit of a worry is that when the car is at idle then fan slowed down or held down and car started at work the way i test viscous fan hubs as i let the car idle then get a bit of card board to try wedge it to slow it down if it slows down quickly means the clutches inside are knackered prob reason why when acclerator is stabbed the fan is not keeping up with speed of engin just slipping on the spot do the test see how it goes good luck with it mate
https://www.sau.com.au/forums/topic/241325-water-pump/#findComment-4342799
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
