Hi guys.
Some of you will know that I have been having the engine light SLIP light and TCS OFF light coming on. it did it this morning on the freeway and I realised the engine was running badly. I pulled over and shut the car off. After about 2 minutes I started it and it came good again. it felt like it was only running on 5 cylinders or something. It was really shaky and sounded like it was struggling. I really need to get this sorted out ASAP. Im in Osborne park and really not looking forward to driving home tonight. do any of you know what the problem might be? And also where around here I can maybe take the car at lunch and have a diagnostic done? With my working hours I don’t know where I would be able to because every were is closed before I get to work and by the time I get home.
Regards,
Edited by Rucker34
https://www.sau.com.au/forums/topic/241349-help/
Try Danny in Osborne Park,
"Japanese Performance Centre".
Really good bloke, sells parts but he knows his engines and that.
Doesnt hurt to ask I guess and its close by.
Unit 11/ 28 frobisher street Ozzie Park
92010400
https://www.sau.com.au/forums/topic/241349-help/#findComment-4213193
maybe try go to nissan in ossy park just off scarb bch road?
not sure if they will charge u ne thing but maybe go in n tell them ur situation n maybe they can point u where to go?
I drove around to heaps of garages at lunch yesterday with no luck. I drove home and didnt have a problem last night thankfuly. I got the train today lol.
I didnt bother going to nissan because i already knew they would not be able to help me. With the last car when my keys got stolen they were not even able to help me with anything other that ordering the new keys. They also said they were not even able to get a workshop manual for that car (well one that was in english any way)
i am going to have to try to find somewhere that i can take it to tomorrow.
Can any one recomend a good workshop that should that the car to that will be open on a saturday?
https://www.sau.com.au/forums/topic/241349-help/#findComment-4215370
Imports101 is sometimes open on a Saturday morning but only early, they close by the afternoon... it's best you call them and ask them just incase...
Imports101
1/25 Forward St
East Victoria Park
Western Australia 6101
Phone: (08) 9355 5101
Fax: (08) 9355 5102
Mob: 0403 065 666
https://www.sau.com.au/forums/topic/241349-help/#findComment-4215826
Ah yeah they helped heaps thanks mate. Had it hooked up to the diagnostic today and the fault is an ignition error. Im guessing it would almost definitely be the coil packs like every one else. The diagnostic cost 90 bucks. My girlfriend took it in. Seems bloody steep for a 2 minute job? all they do is hook the laptop up to it and it tells them what the fault is.
https://www.sau.com.au/forums/topic/241349-help/#findComment-4216954
Does any one know where i can go and buy my self some spitfires? or one of the other brands, i remember reading somewhere about a couple of other brands that are ment to be good (or am i best to just get the spitfires?).
im not really all that sure exactly how it all works but im guessing it is my coil packs that are gone. are spitfires a direct relpacement for these? or something totally different?
Edited by Rucker34
https://www.sau.com.au/forums/topic/241349-help/#findComment-4217233
ok i have no patience so i have already gone onto just jap and paid for a set of JJR coil packs. i hope it was the correct choice and that it fixes the problem. I think i will make sure i get myself some good plugs and find out what the best gapping will be for them while im at it.
Edited by Rucker34
https://www.sau.com.au/forums/topic/241349-help/#findComment-4217740
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
