It will depend where the thermocouple is placed as to what sort of reading is obtained.
Pre-turbine will be significantly higher - you would see up to 150 degC differential across the turbine.
Then the further down the dump, and to some extent the angle + depth of intrusion into the gas flow will impact the reading obtained.
That said, running @ ~ 12.2:1 AFR @ full load and high rpm on an acceleration run will get me 810-820 degC with the probe placed 100mm post turbine and probe at least 40mm into the pipe.
I get up to 800 deg C using a 1.6mm K-type thermocouple mounted in the exhaust manifold...
One thing you need to remember is that the thermocouple indicate the temperature of itself at the junction, and not the gas surrounding it. So the indicated temperature will be slightly lower than what the actual temperature is... How big the difference is will depend on the size of the probe and rate of increase of the exhaust gas temp...The smaller the probe the better from a measurement point of view, but vice versa in reliability sense..
Also most thermocouple readers are digital and update at different speeds..If you get a temperature peak between in between updates you may miss the actual peak reading...
IMO Due to all the variables involved EGTs are best served as a warning that something has changed (ie sudden change in EGTs) rather than an overall indication of whether your tune is perfect or not...
My EGT's will go over 900C if I stay in the throttle long enough. I have a greddy EGT gauge, the probe is mounted about 3-4 inches from the head right after cylinder 6's runner.
This pretty much freaks me out. It can only be retarded timing, or a lean condition contributing to the high EGT's right?
I'd love to get this sorted out.
Wont 950C+ start to melt cast pistons?
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
