Thanks for the photos, Satanic.
I was trying to figure how it would fit under the boot hinges.
I guess its quite different from the R33, where that had a bracket that sticks out as well.
From the photos, you had to cut the lining right? Just a small slit?
Yeah, the rear strut doesnt do much.
My R33 felt the same when I installed one.
Mainly for looks. :ninja:
Damn, why cant Nissan make more parts compatible between the R33 and R34 :down:
i hear that it makes little to no difference...front strut and sways will be all u need...after coilovers or a spring/shock combo of course...
Can confirm that.
The front strut made a massive difference... best bang for buck in regards to handling mods for sure! 2nd hand cusco front strut braces are 100-150 depending on condition. Piece of cake to install as well.. Not sure why these didnt come stock ?
Does the strut make much of a difference? Keen to put one in mine when I can.
Made heaps of difference on mine, tightened up the rear end a lot.
You're hearing wrong... and no, those parts are not ALL you need... furthermore, R34s came standard with a front strut brace that more than does the job, why the hell would you replace it? So tell me why you'd NEED to do that?
Yeah quick n easy install... those photos are almost 2 years old now. Some dude who did it in Japan had to grind away the edges on the brackets as he was fitting it to a 4 door. As for the trimming, you are spot on, just a small cut here n there so the brackets fit through.
Can confirm that.
Are you talking about the same car here? R34s did come standard with a front strut brace, not sure how that can be "bang for buck".
Obviously not.
You can clearly see my avatar has an r33 in it.
and under that it says my car is a r33.
so now you can see how its a bang for buck handling product.
If your car has a subframe that all the rear suspension arms bolt onto, the rear strut brace does nothing as the subframe provides excellent rigidity. If the upper arms bolt onto the body (like in the front) then it would be worthwhile.
Remove rear trims... all will be revealed. On each side there are 2 threaded rods poking out, this is where the Cusco brackets bolt to. It's almost as if Nissan was going to put that exact item there, but ran out of money or something.
Umm...relax? I read/heard from SydneyKid's threads...so go tell him he's wrong. I'm just passing on what I heard/read. I didn't say R34's didn't come with one standard...nor did i say it needed to be replaced...I was simply saying that thats probably all he would need for a decent setup...
  • 8 months later...
a bit of an old dig up on a thread (although i thought better reviving one then making a duplicate).
my question is where can i get one of these rear strut braces...i know cusco make them but cant find one...
cheers in advance.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
