  • Replies 58
Posted Images
Yea from 3 to 2 lanes just past the truck inspection bay.
But there is a flash unit behind it. I think its a speed camera, but the camera full points towards the other side of traffic. Check it out next time and see for yourself.
I drive to gong nearly everyday so i will keep a look out for a new speed camera sign (if it is a speed camera)
Comes to a point where you just say no more..
I want to take an angle grinder and go to work on as many fixed speed cameras as I can.
I agree lets cutem down!just another revenue raiser.
If they where serious they would make the vehicles attend the RTA to qualify the defect, then get repaired the said problem.
Edited by YLD-CHLD
I think they are targeting trucks using compression brakes,,,not us. Let face it,,,going down Ousley would normally be done on a trailing throttle,,,no skylines going to break the limit of a noise box.
Oh and some of my good old friends are bikies,,,sure their bikes are loud,,,but they are cool dudes.
Neil.
hard to pin a recording of air brakes on a particular truck...
From what I've read, the system uses several microphones. If they're directional enough, it shouldn't be impossible to triangulate the source of the noise.
Putting it on Mt Ousley Rd, on such a steep section of road, is just bollocks if you ask me. There's not much by way of housing out there, and there's sound barriers, and I'd rather there be a little noise than trucks having no brakes at the bottom of the hill.
Oh trust me, I know how that part of it would work :)
My point is, you would still need a picture of the vehicle in question. You can't just play back a recording and be like, "I put it to you mr trucker sir, that these ARE your air brakes..."
The system takes a 10 second video recording to go with the audio and triangulation data.
Wonder how many DB a joint fart can produce.
I reckon we just find out where the mics are, and just set up a birdseed tray in front of them.
Some of those birds make a massive racket, and if the government tries to shoot or poison them all those nature types will kick up a massive stink.
Bonus points for someone who can figure out how to make a kookaburra shit on the camera lens.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
