After long running dramas, my R32 GTR is back on the road.
It is running well. I love it. Many thanks to Glen from ESP for finishing off the job.
So, what was done to my car...
- Radiator flushed, removed all rusty gunk
- New coilpack
- New wiring loom
- Radiator top tank replaced
- New HKS throttle body and inlet manifold gaskets
- New oil and filter
- New fuel filter
- New silicon radiator hoses
- New metal pipe assemblies
- New timing belt
- New fan belt
- New tensioner pulley
- New idler pulley
- New thermostat
- New water pump
- New crank seals
- New platinum spark plugs
- New fuel hoses
.... etc etc
Total expense was over $6k. I lost count.
https://www.sau.com.au/forums/topic/241493-its-back-on-the-road/
I'm looking to replace the turbos. Any recommendations? I looked at SAU traders list, saw Garrett turbos for about $2500. Anyone bought and tried these?
I'm not so keen on high power, but I'm more keen on getting my car reliable.
Any comments or ideas?
Yes I have them, but there are many varieties. 2860-9/-7/-5 are all the same price approx max KW 290/310/350. (very rough)
if you are not after power the 2860-7's (similar to N1 turbos and the HKS GT-SS kit) are probably your best bet if you want to push them they are capable of ~320kw the 2860-5's (similar to HKS 2530's) are more of a 350-370kw setup.
Ditto -7 or -5
I currently have the -7 and I think I'm reasonably happy with them. I'll let you know later this year if I'm happy with them or not. They'll finally be able to be pushed to show some potential soon! :O
Do some reading into the -9 though because I have heard that they are a fantastic turbo and are very underrated!
After long running dramas, my R32 GTR is back on the road...
I kept having to squeeze past your car in my garage, so I got a pretty good look at it numerous times... Very neat and clean. Curious about the MR2 club sticker on the bonnet though :O
I kept having to squeeze past your car in my garage, so I got a pretty good look at it numerous times... Very neat and clean. Curious about the MR2 club sticker on the bonnet though :)
I'm still a committee member / webmaster for the MR2 club of Australia and the ACT division. I ran the club in 2005 when I had an MR2. I don't think Glen remembers, but he dynoed my MR2 when he was working at DTS many years ago.
Thanks everyone for the info on turbo, I'm very much considering to buy Garrett GT2860-5 or -7 in near future.
Edited by zenith13
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
