Motor has been built by Ricol Automotive and has just clocked over 10,000kms. Currently running on factory computer. Brand new Apexi PowerFC with Boost Kit Available. Brand new Nismo fuel pump, Injectors and Z32 Airflow meter also available. Genuine reason for sale. Will be really sad to see her go :)
Engine
RB30DET (RB30 Block with RB25DET Head) Built by Ricol Automotive
CP Forged Pistons
ARP Head Studs
Cometic Head Gasket
New RB30 Oil Pump
New RB25DET Water Pump
Bottom End Rebuilt using Genuine Nissan Parts
Variable Cam Timing Oil Lines Connected
Decked, Honed and machined block
Full Nissan Gasket Kit
20thou Overbore
A'PEXi AX53B70 P25 Turbo Kit
HPC Coated Exhaust Housing
A'PEXi Super Suction Kit
A'PEXi Pod Filter
Custom Stainless Steel Split Dump Pipe (Heat Wrapped)
Unique Auto Sport Fibreglass Cold Air Box
Greddy Forward Facing Inlet Plenum
Greddy Throttlebody adaptor
D1 Front Mount Polished Intercooler
Splitfire Coilpacks
Fujitsubo Catback Exhaust
Sard Magnetic Sump Plug
3" Metal Catco Cat 5" Wide Body
GTR BOV
Ross Metal Jacket Harmonic Balancer
HPC Coated Exhaust Manifold
Handling / Braking / Wheels
A'PEXi Hard Tune 'Down Springs'
A'PEXi Strut Brace
Nismo LM-GT2 18" Wheels 8" Front 9" Rear
RDA Slotted Rotors Front & Rear
Bilstein Adjustable Shocks
Whiteline Camber kit
Bendix Advance Brake Pads - Front
Ferodo GP2 Brake Pads - Rear
Drivetrain
OS Giken STR2CD Twin Plate Clutch
Redline Oil Gearbox & Diff
Nismo Strong Release pivot ball
Exterior Styling
Nismo Smoked Side Winkers
Nismo Carbon Fibre Side Pillars
Nismo Front Bar
Interior
Greddy Turbo Timer
Nismo Gear Shift Knob
Nismo 320km/h Dash Cluster
A'PEXi EL2 Boost Gauge
A'PEXi EL2 Oil Temp Gauge
GReddy A-Pillar Pod
^^^^ car now has 18" Nismo LMGT2s with brand new rubber. Will update pics later.
Please PM for more info
https://www.sau.com.au/forums/topic/241523-rb30det-r33-gtst-1995/
Has not been dyno'd yet mate, only just run in on std injectors and ecu hence the low milage. With it setup with the PowerFC etc I have, it should be atleast 270kw+ with plenty of torque... I wasnt after a lag monster when it was built.
Edited by MintR33
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
