I'm in the process of rebuilding right now and searched and found everyone recommends 26 rods into the 25 as a cheap upgrade.
There seems to be alot of people runnin up to 280-300kw on stock internals with out any rod damage, so my question is: how much a stock rb25 rod can really handle?
An if anyone has broken or bent one pls state at what power an rpm levels.
The reason being i dont have acess to any used 26 rods an im only aiming for 260kw.
I think Sydneykid quoted somewhere here that it was the rod bolts that were more proned to damage rather than the rods themselves.
https://www.sau.com.au/forums/topic/241529-anyone-ever-brokebend-25-con-rod/
for anything under 280rwkw the stock bottom end is fine. IF you have the engine appart and are rebuilding DONT even worry about forged pistsons.
Use the stock pistons, stock conrods. and use a decent set of ARP rod bolts and you will be fine anywhere up to about 300rwkw.
Upgrading ANY other parts internaly for less then 300rwkw is just a waste of money, and if you want to waste money I can show you a way to do that. I will send you my bank account details :)
Im an advocate of stock RB26 rods...as im yet to see a rod fail due to its lack of strength...its always something else that causes the rod to fail.
RB25's would be in the same boat...but not as good as the 26 rods.
put some ARP's in the stockers and they will be fine...i ran stock rods in my RB26 and they were good as gold when measured up when i pulled the engine down and the engine was making 450+AWKW and was punished at the track regularly.
Edited by DiRTgarage
u can buy spool rods for the same price as gtr rods nowadays man.
spool rods are only about 600ish man.
if u do a cheap job, be prepared to come back to it.
you can pick GTR rods up for $150 a set
600>150
i built and raced an engine for 4 years using all Nissan parts except pistons and camshafts
its not how much $$ you spend...its how its screwed together
600>150
Single Apexi RX-6 turbo on mildly tuned RB25. Tomei rod bolts, 7750 RPM limit. Admitedly engine had done a LOT of track days, but never over revved. looks like bolt failure, but the engine I am building to replace it will have either RB26 rods or Carillo / Tomei in it.
Full pics at http://www.gatesgarth.com/bang/bang.html
Expensive...
You wont find many
1. Usually its the rings that go first
2. While the motors are apart, most people either upgrade them to RB26 or aftermarket
Hence its gonna be hard to find a pushed RB25 rod. Only a couple of instances of it
I bent an RB25 conrod, the engine was making around 210-220rwkw at the time. I only noticed it as it was making a slight ticking noise as the piston was hitting the oil squirter due to the reduced rod length.
When the engine was pulled down the bigend bearings were ok and the rest of the motor was ok only a sligthly bent number 1 rod.
I still have it hanging on the wll in the shed if anyone wants pics.
pls post
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
