This was going to be our next drift car but something else has come up (secret) so we are offering this for sale.
i should mention this is a complete car minus headlights and has VERY VERY slight front left damage (few 100 bucks), minus engine and trans BUT the interior is complete and undamaged front seats removed and stored safely.
We can supply it as is or we can complete it to any stage you may require. ATM it has bulletproof full R34 GTR rear end (diff, cradle, suspension etc) R34 gtt front crossmember and rack. We are happy to swap front end out if someone to refit SR, we have a few SR20 (jap s15) engines here so we can install it as supply it as a full runner.
Car also has genuine yashio factory front guards and is auto, can supply manual parts if need be.
$6k ono pics up soon
ps can also supply the RB26 that was destined for it..... or we can complete the car to track spec if so be it.
Edited by URAS
selling the engine as well???
yeah, full built RB26. (unstarted)
R33 N1 crank new
greddy pro cams
greddy springs
reco head (all new valves etc)
greddy pistons
H beam rods
greddy oil pump
greddy cam gears etc
plus all the usual things, extra drain, oil restrictors etc
complete engine minus bolt ons. $9k
Edited by URAS
  • 1 month later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
