Hi guy as the title says every time i start the car up and i go to push in the clutch i get a whining noise? But after i start to drive for a bit
and i depress the clutch that noise disapears. This just started happening suddenly. </br>
my car is a r33 s2 with a cushion button clutch. any ideas will be greatly appreciated.</br>cheersJim
Mine has the same problem.
I wouldn't worry about it to much unless it get's really bad.
How are your guys gear boxes holding up? The synchros in mine are a bit worn i think.
Is anyone else having any problems with there gear changes my clutch is a twin plate rpm type it's not slipping..
Hi does anyone know how much it would cost to replace the spigot bearing? When i got the clutch installed roughly 6-9month ago im sure they charged me extra to fix this or replace the spigot bearing and for it to break again is fu####en unbeleivable.
It will be the input shaft bearing. Definitely not the spiggot and unlikely to be the clutch throw out bearing.
Input shaft bearing noise - Common for the RB20 box's in almost any condition and common in the rb25 and 26 box's that are thrashed.
Eventually they will fail. Generally smash a gear or two due to the bearings being noisy/slack/loose creating tooth mesh issues.
