Hey, i bought a R34 GT-T about a year ago and would strongly recommend you look at one of them before you buy a r33. There is nothing wrong with R33's, but you cant beat the look of the R34. Not only that the R34's have a revised engine that has more power and they also have tracktion control which is a great thing for chicks in the wet. Im not sure excaly what models have traction control but mine is a 98 R34 GT-T series 1 - 5 speed manual 2 door coupe. And i know you can get them with a sunroof too.
Well, after looking at numerous skylines, for some reason I prefer the look of the R33. I have no idea why, it's just the R33 is more appealing to me. I still like the look of the R34, both are nice looking cars exterior wise, but I'd just rather the R33. As for traction control, I couldn't really careless to be honest. My XU6 doesn't have traction control and I can throw that round corners quite well in the wet.... For a chick.:(
Edited by Manda2365
It's supposed to work at various speeds and only kick in when loss of traction is detected, as is my understanding. Maybe others can also confirm this?
Nope, if you read the image you posted it actually says that it's "varying the angle of the rear wheels in relation to those up front" and "sensing vehicle speed and your rate of turn"...
HICAS still works in GTS-T's without ABS or G sensors so there is no way for the HICAS system to detect traction loss. Its simply calculated on the front steering angle VS vehicle speed VS steering rate of turn.
It usually only works over 80km/h.
It's definitely not a parking aid, how can it be when the rear wheels only vary by one degree? Someone might be thinking of the old preludes: http://au.youtube.com/watch?v=b0sVD17WSdQ
^Ah I see makes sense Thanks :)
regarding the 1 degree, like I said only what I've read here. Some other websites I've came across seem to have confirmed this. I might be able to find some later, cheers
You may be in luck Amanda,
There's an R32 GT-R being prepped for sale at Top Secret Imports here in Blacktown, Sydney ATM.
It has done only 80,000Kms and the interior is absolutely like new!
Your budget is $20K and so is this. No modifications except for Susp'n/Springs & exhaust.
I came across it to-day and it has no rust whatsoever.
And I have no connection with that company.
Hope this helps...
Tez
  • 1 month later...
Hey Guys...
It's been awhile since I last posted in this as I was on holiday in Tassie when I started the thread and the Skyline I had my eye on was sold before I got a chance to look at it. So I'd put off the search for a Skyline as there wasn't much else that caught my eye. Until now....
Another one has come up for sale. Same deal...1995 GTS-T, White, Sunroof yada yada...
It looks to be for sale at the same place as the other one, and I'm almost convinced it's the same car. Only it's 2k cheaper. Should I be worried about that? It's advertised for roughly $9k + on-roads. Is that too cheap? Should I be a bit iffy about it? Also, if it is the same car, I guess I should be concerned as to why it's for sale again a month later at a cheaper price, yeah?
IF its the same car.. just means it might not be selling.. enquire as to whether its the same car and why the price was lowered.. for 9K i'd be concerned that it may not be in top cond. but that could be anything.. get a mechanic (racv is good for victoria) and get a full test done.. just go over it with a fine toothpick and magnifying glass and be happy that its not a dud before you buy
I was under the impression hicas only kicks in above 70kph anyway?..
Its a weird feeling but ive never really had an issue with it..
Been a skyline driver for 2 years now.. and its fantastic..
1997 R33 GTSt Series 2..
You shouldn't be paying anymore than $12K for a good condition R33 Series 2.. people advertising over this are dreamers..
Mine is in perfect condition except for the gearbox needing some attention and i wouldnt expect over $9k if i sold it..
$12k for a good condition R33 Series II? In Adelaide here its about $12k for a good condition Series 1!
At $20k I'd be looking to spend it on an R34 GTT or late model R33 Series II and splash a few bucks on it.
If you know the VIN, put it in here:
http://raws.dotars.gov.au/rawswebpublic/RAWPubVehSearch.asp
and you can see who imported/complied it. Do some research as that could give you a clue as to what type of cars they bring in.
Feel free to cruise by our showroom, we've got an R33 Series II and R34's in stock now.
cheers,
David @ Carizma
Thanks for that, that's great information. The one I'm looking at is unmodified and according to the website it's recently imported from Japan, not yet registered here. It looks untouched from the photos, the only mod I can see so far is the exhaust.
As for the 4-wheel steering, after learning from you guys that it doesn't affect day to day driving, I'm not worried about it. I'm not exactly the type to be flinging it sideways at every corner. >_< And like I've been informed that if I really don't like it, I can get the lock-bar? put it in and it'll be like it was never there....I hope.
What's the deal with imports being registered? Is there any chance I could end up with something dodgy, compliance wise? Is there any way I check things like that?
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
