I brought this TIG 3 months ago, i was going to do a tafe course on tig welding but my dad just gave me his mig which im using to build a trailor. It is still under warranty, and it comes with a receipt for $1,600 comes with tig hand peice, regulator, fittings, everything needed except gas! also comes with a STICK hand peice.
$1000 obo
* Ideal for all TIG Applications - INCLUDING ALUMINIUM!
* Latching for continuous welding.
* Generator Safe!!
* Includes TIG Torch and Professional Regulator
'Inverter' technology
* Post Flow Gas
* Downslope
Duty Cycle
60% at 160 Amps
100% at 123 Amps
https://www.sau.com.au/forums/topic/241569-ac-dc-160amp-tig-welder/
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
