Hey guys,
My mate just blocked the standard bov on his r33 gts-t, by blocking the hole with a plate, and bolting the bov on top to hold the plate flat.
Now, occasionally, when rolling to a stop, and clutching in, the revs drop to 0 and stall.
Is this a common problem? Or is there anything that can be done to avoid this?
Thanks boys
Closed.
Please search, this has been covered plenty and plenty of times...
and as i get to have the last word... serves you right for blocking it, the stalling isnt as cool as the flutterzzzz now is it? :/
Guest
