I cant get the rear wheel alignment bars off the hub assembly. the bars that connect to the hicas. i have removed the pin and nut and wound the rods in, bashed it with a hammer from all different angle including moving the hub assembly up n down with a jack, removed the rod totally from the hicas even and i still cant get it of. also tried soaking it in inox and then again all the above... both sides just wont budge off the shaft.
anyone got any tips?
Are you talking about removing the ball joints at the end of the alignment rods from the hub? If so you need a puller like this;
Those ball joints are called tie rod ends. The alignment rods are tie rods.
you can also get the off using a "ball joint seperator" a big fork that you shove under the end of the arm and smash with a hammer until it pops off. It can take some real heavy hits to free it up.
if you have been whacking the threaded rod end to try and push it back through the arm you have probably stuffed the ball joint :( if you are going to fit the end of a threaded rod you should always put at least a nut on it to spread out the force
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
