That's only true if you excessively heat the wire, good solder technique doesn't do that, you've fluxed, tinned and joined in under a second. 275 degrees for 1 second does not "work harden" copper. Excessive heat and excessive contact times does. I'm currently soldering IC components with copper wires around 1 micron that are highly vibration sensitive and can make a proper joint without raising the component above 70 degrees and have them perform with no dramas.
That's 100% true with welding, but then again how many degrees are you using there and what sort of contact times???
Come off it, 0.01v exponential or not does not influence bugger-all on an airflow curve...you'd see more of a voltage fluctuation from the change in resistance of the copper wire with engine bay heat....its been hot this week and my car hasn't plunged into an irreversible voltage chasm.
  • Replies 60
I've actually tested shielded vs unshieled, around the time I put the Z32 in my car. The difference was nothing of note. The funny thing was the rest of the loom in the car that is unshielded actually causes more background "bullshit" than anything. The other thing was going from standard coils to splitfires saw me having to use ferrites on the cable going to the ECU so the datalogger didn't cut-out.
With the soldering I found some details.
For splicing, soldering is the go
In-line joints, if soldered it must be done so the solder doesn't wick too far down the joint (excessive heat and solder) and cause a stress point, twisted joint is a must.
In-line joints, if terminals are used, they can be joined but must then be soldered or heatshrunk with glue impregnation so they can't come apart
It's a matter of personal choice which way you go, but the last two are minimum requirements for auto
The key to soldering is you MUST have a good quality Soldering Iron, that is actually hot enough to just touch the wires and join them like said above.
Keeping a slightly cooler Iron on there for 3 or more seconds is when you get the hardening i believe.
Got my 2nd hand afm today , have just installed it in the car and tried it, same problem, car will not start with it plugged in, unplugg it and it will start and idle 100% perfect, i even tried pluggin the afm back in while the car was idling and it just dies.
Either i have two faulty afms here or theres is a problem somewhere else.
Does anyone know if the afm circut has a fuse or a relay anywhere?
Need some more help, dont really want to take the car to nissan for them to sort out.
I may have missed it but have you posted a picture of where the wires are going on the AFM yet? I know you are saying they are all correct and chances are they are correct, but just to cross it off the list could you take a photo of the coloured wires going into the afm and the configuration that you have wired them please.
Cheers, Daniel
DAN, I am not referring to inside the ECU. The ECU itself does not suffer movement of internal components. The loom, however, can move around etc. The solder does damage at even 70deg (god knows how you are measuring that anyway). It is a well known fact that solder makes the wire brittle beside the soldered joint, no matter how good you are. Most of the crimp terminals you are probably referring to are the insulated red, blue, yellow ones? I am not talking about these dodgy terminals, I am talking about proper wire joining crimp terminals. Motec sell them and, like i said, Nissan, Toyota, Mazda etc, all use them on their looms. Unwrap a few and you will see.
Also, if you want to do a little experiment, put a potentiometer on to you signal wire for the AFM and change the voltage 0.01V at a time and datalog the results. Let me know when have the results and I will point out every part of the map where you increased the voltage by 0.01V
Cheers, Daniel
There is a pic (not very clear sorry) on page 2, post#22, ive connected the 3wires back up to thier corresponding colours just like they were before i cut the standard plug off to fit the z32 afm plug, im thinking maybe i somehow shorted them out while i was soldering them and blowing a fuse or relay or something.
Have just looked at a fuse box diagram in english and i cant see anything on there for the afm, only thing that comes close if "Engine Control"
Will go out in the garage again tonight and check all the fuses just to make sure.
You're missing a wire dude, you haven't linked the ground on the Z32 side.
Im using the stock afm, hence only 3 wires lol, you must be thinking im using a z32 :P
I previously had a z32 wired up correctly, was running sweet, its only now that i have changed back to the stock afm that i am having problems!
Cheer
LOL just saw that, you've gone backwards with mods :P
Sure have haha, going to sell my car as standard so i can cure my gtr obsession hehe, this is the only thing stopping me from actually putting it up for sale at the moment though lol. :P
Cheer
The only way you could blow a fuse while doing that would be to do the swap with the ign on. You didn't do that did you?
Check all fuses, you're bound to find something there. In the event of no blown fuses, check continuity between the ECU and the AFM again. Then check the signal at the ECU. Also, sound stupid but make sure you have the ECU plugged in correctly. They have a habit of plug misalignment when pulling them down with the 10mm bolt. push down hard on both ends and re-tension the 10mm bolt if the plug went in further.
Have just checked all fuses, they are all fine, 3lit3 32 im pretty sure the connector would be plugged in fine into the ecu as i have unplugged that many times and its never given me a problem at all.
In my opinion i reckon it has to be a faulty afm, so looks like my original one had died and i then bought another dead one, just my luck, i will try and get my car to nissan tomorow to see if they can source exactly what is wrong with it.
Hmmmm, this is starting to get pathetic, ordered a brand new afm from rhdjapan last week (was quoted 1000nzd from a couple of traders on here, even they were shocked at the price when they gave me a quote), just received it today and have just tried it, same f*kin problem, car will start (actually starts a little bit better with the new afm) but then will just stall straight away, unplugg the afm and guess what? i starts and idles perfect, plugg the afm back in and it will die right way.
Have just checked how well the wiring loom connector is plugged into the ecu and it looks fine, checked all the wires coming out of the connector and cant see any problems there.
I dont know were else to look, but it has got to be a wiring issue for sure, i just dont know how the hell to figure out whats wrong with it, or a ecu fault or something.
Would appreciate any more suggestions as this is really really starting to get to me, i cant even get it up for sale because i cant get it running :(
Cheers
Edited by nizmo_freek
Have you touched the fuel pump at all recently?
Had a car here that had those EXACT same symptoms just a week or two ago...
Fuel pump had nearly 100% died.
New pump, fixt.
Not saying this is your problem, but have you touched the fuel pump recently? If so, go look there...
New pump, fixt.
Havent touched the fuel pump at all, its a nismo pump thats about 8months old anyway and was working perfect before i returned my car back to stock.
I dropped my car off to an auto electrician this morning so im hoping he can find the problem, if he cant find it i dont know what im going to do lol.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
