Hey everyone.
I just recently got my new 34 GT from top secret imports in blacktown. When i test drove it before compliance it was an awesome machine. Gearbox was fine from 1st to 5th.
After waiting close to 3 weeks for compliance and rego i get the car back take it for a drive to get some petrol and on the way home changing into 4th at about 4000rpm or above no matter how hard i push the clutch into the ground it crunches in 4th and 5th.
at lower revs it pops into 4th but still crunches into 5th no matter wat. I think since compliance they have stuffed up the sychros so I have since taken the car back and they are looking into it but i thought i might do some asking around to see if anyone has had a similar problem. (tried a search nothin specific enough).
Anyways my questions are,
What could they have messed up with on compliance?
Was it just not put back together properly so the clutch doesnt release the gear properly?
and why wouldnt this affect the other 3 gears?
Anything would help give me some piece of mind.. Been nothing but a headache since i started compliance and i dont want to think i have bought a bodgey skyline after drivin it so nicely before.. Lost the car for another 4 days too :P
And may as well ask while im here.. what does this sticker mean.. its like a green clock with the 3 highlighted and some writing around it
https://www.sau.com.au/forums/topic/241686-r34-gearbox-drama/
Parking permit???
Im sure someone took it for a thrash before pickup; basically downchanging hard and snapping gears *no f*kkkkn respect for other peoples property*
Cmon how many times have we heard of mechanics and apprentices writing off cars? I know a few and the stories are all the same.
yeah sounds like it's a synchro issue.
Would they even touch the gearbox in compliancing?
Hope you sort it out
My 34 does this also, and has for the last 2 years. I don't think its a major issue so haven't worried about it too much as its not getting worse. Check out these threads on the same topic.
http://www.skylinesaustralia.com/forums/Be...gears+crunching
http://www.skylinesaustralia.com/forums/Cu...gears+crunching
Possibly when they changed the gear oil at compliance,
The oil they used may be too thick, if the synchro's where abit warn the thicker the gear oil, the harder the synchros have to work to cut through the oil to mach gear speeds.
I was also told by the guy that complied my 34 to change all the fluids again due to them using poorer quality and cheaper fluids.
100% agree; use redline superlight shockproof. very light and even compatible with getrags which need an auto fluid.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
