Can anyone tell me if the front brakes off a 32 GTR or a 33 GTST can be fitted on the rear? or for that matter if there is any benefit in doing so.
The main issue that I can see is that the thickness of the front rotors is 32-30mm and the best that I have found in a rear rotor is 22-20mm. Can the calipers function poperly when extended an extra 10mm.
I know that I will have to adjust the brake balance, but i believe that there is an adjuster on the ABS controller which should fix this.
I am upgrading the front rotors and calipers and figured since the standard ones aren't worth much, they would be better served on the rear of the car.
Any comments appreicated.
https://www.sau.com.au/forums/topic/2417-front-caliper-to-the-rear/
