My HICAS light comes on when i go past 100 killometers like on the freeway for example then when i switch my car off then back on again it is off, anyone got any ideas? my car still runs exactly the same when the light comes on its a bit of a mystery and i dont want to pay to get it looked at if its nothing...
My car does the same thing, HICAS light comes on after a few minute of driving ~100km/h.
Do you have after market steering wheel? From what I have read before on here, If you do, then the sensor on the steering wheel part has stuffed up or not connected properly when the after market wheel is installed.
Either way, its probably the sensor(s).
im with u guys after market steering wheel my old r33 done it and so does my new one it only come on when i was sitting on about 80ks they both have after market steering wheels
Interesting, I had the same problems with a stock steering wheel, but this was *after* the aftermarket steering wheel was removed.
Anyway, you only save weight on the R32's, not the R33's, lockbar is an option (and removing the globe). See the tutorials section if you decide to remove it rather than try to fix it.
when i took mine out i was quite surprised at how heavy it was...
n.b. do it on a hoist if poss... it was a bloody annoying thing to do from under the car!
when i still had hicas i drove to sydney and after 4+ hours of 100kph driving it then came on....
now its just permanently on and i done even notice it
you are all getting the problem for the same reason - the steering wheel is not on straight. As far as HICAS is concerned you have been driving in a circle for the last 5 minutes so it throws an error. You notice it on the freeway or at higher speeds because you are driving in a straight line for minutes at a time
you need to pull the steering wheel back off and put it on straight (the hicas sender is in the boss kit). if the car now turns with the wheel on straight, you need a wheel alignment (a previous alignment may have adjusted for the previously crooked wheel)
While you got the steering wheel off, clean the steering sensor too. Mark it with a permanet marker so you know the original position and clean it with WD40, wipe down and hose off with compressed air to get rid of all the dust.
But before that
Check your HICAS fluid and top it up.
If it still comes on after topping it up, do a wheel alignment.
If it still comes on, get your mechanic to run a diagnostics check on your car to try and trace any faults.
Issolate the fault and fix it from there.
But before that
He has an R33, their HICAS is electronic not hydraulic (there is also no seperate "HICAS fluid" to top up in R32's, it runs off the power steering circuit).
i have only had my car for about 6 weeks, as far as i can tell the steering wheel is your standard skyline wheel the guy i brought it off had every intention to keep the car as stock as possible so i think it is the origional wheen but i'll take it off this arvo and scope it all out...
who would remove it tho? i dont live anywhere near the city so there are no real experienced people when it comes to imported cars, my local nissan dealer knows jack shit about skylines because its more of a 4x4 dealerwould a local mechanic know about HICAS and how to correctly remove it?
  • 1 month later...
This happens to me, but ONLY when i drive at 110 not 100 and only after driving on the highway for over an hour (I drive half an hour on highway to get between my home and town every day.)
I've got a HICAS lockout bar and stock steering wheel, but the car does need a wheel alignment, so possibly that could be the cause.
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
