  • Replies 117
got mine today. i can see me f**king it up to put it on...
wipe area to get clean
pull off blue backing tape.
place sticker on...go over with card to get rid of bubbles...
peel off clear plastic
done?????
BTW thanks heaps....looks sick and perfect size :)
Edited by Gus-
You shouldn't use dishwashing liquid because it takes to long to evaporate, sometimes leaves a residue and the adhesive doesn't have time to stick.
I've got proper vinyl spray, but when I was talking to the vinyl guy he "suggested" any alcohol type cleaning solution would be okay to use.
Another way to get it to position accurately is by using hinging.
You'll need a pair of scissors and squeegee, within your reach.
1. Clean the surface. There should be no dust, it should be dry.
2. Use a masking tape, stick the whole sticker, unpealed, on the surface. Position it accurately here.
3. Peel the backing paper, and trim some of the backing paper with scissors (it should be a clean cut, there should be no paper ripping).
4. Stick the peeled bit.
5. Peel the masking tape off, then Peel the rest of the backing paper. Do not drop it.
6. Stick it down, apply pressure from left to right.
7. Once the vinyl is stuck down. Peel the application film.
Edited by zenith13
A lot of stickers went out today at Marques in the Park. Some people missed out because we ran out.
Frink - Sent
Mang - Sent
Bullet32 - Frink has yours
Rossco_01 - Sent
Ecstacy - Sent
SteadyEddie - Michele has yours
Tarmac- - Sent
Gus- - Sent
Michele - Sent
Zenith13 - Sent
INVRTD - Sent
datto260Z - Sent
CeJay - Sent
OzLeroy - Sent
Bluprint (I got your email) - Sent
Turismo - Sent
ZCR - Sent
Bob - Sent
Glenieboy - Sent
Still yet to hand out:
- DriftGTS
- Rev_head88
- R3sp3ct
I have 2 left, and Tarmac should have 3 spares.
If we run out, I may do another small batch.
Edited by zenith13
How ya going Zenith, If your going to do another little batch of stickers, i'd like to put my name down for 2, and I'd be more than happy to give ya some money for ya trouble. If ya go ahead with it PM me. I also would like to know if you could do a sticker for me that say's SNEEZE PERFORMANCE. If that is possible. CHEERS. ;)
Glen - I still can't picture you in a white car... I hope I don't snob you.
I was snobbed by a white 32 on Drakeford today... 3-4 guys in it.
He He, Its all good. I'm sure you'll get used to it,but I know what ya mean. I've had a couple of times where I've also been snobbed by other skyline drivers, guess they're the ones that just dont understand.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
