Pretty much what it says in the title. I have my eyes on my GF's old 16" Momo alloys from her 200SX S13. I know the stud pattern is the same, but what about the offsets? Any other reason why I can't just bolt them straight on.
I ask because I need to get the alloys refurbished first. One of them is no-longer round due to an unmarked, unlit pothole. Don't want to spend the money if they aren't going to fit.
Edited by Lum
Far as I know m8. I'm sure the stock cefiro's in japan have the pre facelift s13 wheels. Also I've seen a cefiro drifting with a 5 stud conversion with s14 wheels on, so would guess s13 4 studs would fit a 4 stud cefiro.
Hmm stock S13 wheels are different in the UK. That's my car but I take it you already figured that out :P
They're not just the same design with a different offset or anything like that though?
Ah, I think I know what you mean. Those wheels are commonly referred to as SR wheels, because they were on SR20 S13's.
The ones found on CA18 S13's are commonly called teardrop wheels, or CA wheels.
But basically, if it fits on the S13 then it's most likely going to fit your cefiro.
If you are worried there is a thread getting around this section of the forum where alot of people have put descriptions of what wheel size they have (width and offset) and pictures of how they fit. Then you could have a bit of an idea how that will compare to your 16" rims.
Only problems you will have is if you have upgraded to R32 skyline calipers (the 4pot ones) then the S13 wheels won't fit without spacers, and if you put R33 calipers on you won't be able to fit 15" rims.
Are these the S13 rims you are talking about?
Edited by daisu
I think those are the ones yes. Problem is the UK never got the SR20 S13. We got the 180SX S13 (with a CA) up until 1994 then the Silvia S14 from 94 onwards, both were sold as the 200SX.
Looks like they should go on though, thanks :thumbsup:
These are the wheels I have in mind BTW
They'll no longer fit my GF's S13 due to her brakes.
Edited by Lum
Did she upgrade to skyline brakes?
At least you didn't get stuck with the 240sx (KA24 engine) like the USA did.
We didn't get anything in Australia, they are all grey imports, but you wouldn't think that with the amount of them on the road.
Edited by daisu
Well she actually had to buy a new shell because someone drove into the back of that one. It came with R33 brakes on the front and R32 brakes on the back (or maybe the other way around, not sure).
Before that she had a set of Z32 fronts and standard rears. I think I'll be borrowing the Z32 brakes since they're just sat in the shed doing nothing.
And yeah, you're quite close to Japan and their second hand cars are so cheap, I'm not surprised the country is full of them :thumbsup:
And yes, at least it's not the KA truck engine. She's quite happy with the CA (which is running about 250bhp), prefers it to the SR. She knows more about these engines than I do to be perfectly honest.
I think I'm going to prefer the RB to both of them though. I drove a NA 1.8l Mazda 323F with the V6 once and was amazed at how nippy it was, convinced me that 6 cylinders is the way to go.
I'm pretty sure it's a 6" wide rim with +38 offset, I used to have a set of standard cefiro wheels but they don't fit on the front or the rear after I put R33 brakes on.
If your gf's wheels were fitting over the Z32 front calipers, and they aren't fitting on her new 180, then it'll be R33 calipers (as Z32 and R32 front brakes are identical in size).
Also the fact that the wheels I have in mind are going to need some costly repair work as one of them isn't quite round.
Quite difficult to road test and make sure they haven't screwed up the handling when the car is being unsettled by a bent wheel. Not to mention that I wont have the car until January.
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
