High idle will affect your economy a lot if you do a lot of stop-start traffic. Try getting it down below 800. Other than that, just do the usual stuff - replace plugs, clean injectors, etc. Does the R30 use an AFM? If so try cleaning it with some electrical contact cleaner.
https://www.sau.com.au/forums/topic/24173-economy/#findComment-519838
Aftern owning a sr20de silvia for 3 years and getting around 450ks from 45L of fuel it was a big shock how much fuel my r33 uses. The best figures i have gotten are 11L/100ks on highway driving. I average 13.5L/100k in the city but have had it as high as 18L/100ks after a night of hard driving. I guess a relativly heavy car and a 6cyl turbo doesnt help with fuel consumption.
https://www.sau.com.au/forums/topic/24173-economy/#findComment-525244
The best ive ever got from my R30 was something over 400kms out of a full tank. Prettymuch i trash it everywhere, so i dont think thats too bad.
Things that i have done are, new plugs, leads, rotor button and distributor cap.
Other things that will help are cleaning the injectors (one of the best things is to put a bout 250mls of Auto-Trans fluid in the tank next time you fill it up), between doing this and replacing the fuel filter it will make a big diference.
The other thing that everyone with a L24E in a R30 should do is to cut the airbox.
I removed the shitty restrictive cold air feed piece of crap and cut a big hole in the top of the airbox, ill post pics soon.
This made a big diference in power, its much quicker, revs smoother and sounds totaly nuts. I couldnt beleive the diference it made. with the standard exhaust still in place i (Quiet out the back) i have had people ask me if its a V8, others are convinced there is a hole in my exhaust! dickheads.
seriously try going for a drive, just take the airbox lid off and go for a quik spin, youll know what im talking about.
https://www.sau.com.au/forums/topic/24173-economy/#findComment-532038
  • 3 weeks later...
oh man i love you that sounds awsome. Although I have experienced another problem wif 2nd gear this is with cap to. Ok I accelerate fast in first to about 4 - 5k rpm, then i change to 2nd and put my foot down........................ LAg WTf?!? it like does nothing doesnt rev or no power, a dead spot for about half to 1 sec, insanley gay. i have new distrbtor cap, leads, plugs, fuel filter oil filter and this gay thing happens what to do????
https://www.sau.com.au/forums/topic/24173-economy/#findComment-554448
ive noticed since installing new plugs, NGK iridium's and changed oil to the new mobile 1 - super synth and ive actually lost 50-70Km's per tank!!! not sure what going on here! will the wrong gap affect fuel consumption?
will try normal mobile 1 next and see if i get it back!
https://www.sau.com.au/forums/topic/24173-economy/#findComment-558259
yeah i used to get atleast 450Km out of it, but now about 350 - 380 Km's even with highway driving, so i'll check it out!!
noticed alot more noise in the engine since the super synth mobil 1 went in, so see how this affects the sitution before regapping, as fuel consumption was (i think) ok before the oil change!!
https://www.sau.com.au/forums/topic/24173-economy/#findComment-561189
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
