High idle will affect your economy a lot if you do a lot of stop-start traffic. Try getting it down below 800. Other than that, just do the usual stuff - replace plugs, clean injectors, etc. Does the R30 use an AFM? If so try cleaning it with some electrical contact cleaner.
https://www.sau.com.au/forums/topic/24173-economy/#findComment-519838
Aftern owning a sr20de silvia for 3 years and getting around 450ks from 45L of fuel it was a big shock how much fuel my r33 uses. The best figures i have gotten are 11L/100ks on highway driving. I average 13.5L/100k in the city but have had it as high as 18L/100ks after a night of hard driving. I guess a relativly heavy car and a 6cyl turbo doesnt help with fuel consumption.
https://www.sau.com.au/forums/topic/24173-economy/#findComment-525244
The best ive ever got from my R30 was something over 400kms out of a full tank. Prettymuch i trash it everywhere, so i dont think thats too bad.
Things that i have done are, new plugs, leads, rotor button and distributor cap.
Other things that will help are cleaning the injectors (one of the best things is to put a bout 250mls of Auto-Trans fluid in the tank next time you fill it up), between doing this and replacing the fuel filter it will make a big diference.
The other thing that everyone with a L24E in a R30 should do is to cut the airbox.
I removed the shitty restrictive cold air feed piece of crap and cut a big hole in the top of the airbox, ill post pics soon.
This made a big diference in power, its much quicker, revs smoother and sounds totaly nuts. I couldnt beleive the diference it made. with the standard exhaust still in place i (Quiet out the back) i have had people ask me if its a V8, others are convinced there is a hole in my exhaust! dickheads.
seriously try going for a drive, just take the airbox lid off and go for a quik spin, youll know what im talking about.
https://www.sau.com.au/forums/topic/24173-economy/#findComment-532038
  • 3 weeks later...
oh man i love you that sounds awsome. Although I have experienced another problem wif 2nd gear this is with cap to. Ok I accelerate fast in first to about 4 - 5k rpm, then i change to 2nd and put my foot down........................ LAg WTf?!? it like does nothing doesnt rev or no power, a dead spot for about half to 1 sec, insanley gay. i have new distrbtor cap, leads, plugs, fuel filter oil filter and this gay thing happens what to do????
https://www.sau.com.au/forums/topic/24173-economy/#findComment-554448
ive noticed since installing new plugs, NGK iridium's and changed oil to the new mobile 1 - super synth and ive actually lost 50-70Km's per tank!!! not sure what going on here! will the wrong gap affect fuel consumption?
will try normal mobile 1 next and see if i get it back!
https://www.sau.com.au/forums/topic/24173-economy/#findComment-558259
yeah i used to get atleast 450Km out of it, but now about 350 - 380 Km's even with highway driving, so i'll check it out!!
noticed alot more noise in the engine since the super synth mobil 1 went in, so see how this affects the sitution before regapping, as fuel consumption was (i think) ok before the oil change!!
https://www.sau.com.au/forums/topic/24173-economy/#findComment-561189
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
    • Legitimately thought it was a stagea as all i could see at first was the headlights.
