ok i've tried a search on this and couldn't find anyone else asking about the same problem
I have an R33 gtst 4 door S1. The drivers side power window can go down, but doesn't go back up. The motor is fine, you can hear it spinning.
Now i've pulled it apart to try and see what was wrong and i can't see anything wrong. I can manually push or pull the window up and down and the cable thing turns all ok.
Any ideas?
https://www.sau.com.au/forums/topic/241752-r33-power-window-not-going-up/
Pretty common problem, few things it could be
mine was a combination of the relay and the door button panel.
to get it up in the mean time, take your battery out and put it next to the door, then take the door trim off, theres a little plug that you can disconnect that goes to the motor which goes through a hole.
wire up the positive and negative to the battery and touch them on the terminals going to the window motor, if it doesnt work then switch the terminals.
i stripped back the ends of some speaker wire and twisted them together at each end (obviously not the same one that goes to each terminal)
once that's done you probably just need a relay, either that or the button is locked on auto, it's a common problem like i said.
find out which door button panel you have, theres one with a black backing and one with a white (they're different wiring structure if i remember)
but go to an import spares place and just try a relay and a button panel individually, see where the problem actually lies. mine was unluckily in both
good luck
im not convinced its an electrical problem, as i can quite plainly hear the motor working when try to put the window up
i have got a complete motor and cable mechanism on its way from a wreckers now though, so just be replacing everything this will solve my issues
what i suggested to you would have confirmed whether the problem layed in the electrics or the motor/regulator
mine clicked nonstop when mine was the relay
from my experience it goes down cause theres less effort on the motor than pushing it back up. It will sound like its dying when you listen to it. If you do the direct power test as mentioned it would tell you if your motor is on its way out or if its the relay/switch.
i have the same problem in my r32, do i have to take the skin off to test the circuit or is the plug in between the jam of the door ? or in the car ?
im pretty sure the r32 doors are similar layout to r33, im not sure about the skin, but you'll see a small double plug that you can just pull apart and feed 12v down the pins going to the window motor
between the door trim and the shell of the door
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
