Jumped in my car one day to head home and halfway down the road I notice my door open light is on and the cabin light too. Pull over, check everything 3 times, everything is definitely shut. Happened suddenly, no warning and ever since it's been a continual problem the dash light for the door stays on and so does my cabin light. As a consequence I can't set the alarm, it chirps and complains that a door is open.
It's definitely not the door sensors. I've unplugged both doors and the boot, but the harness side still reads a short circuit or near enough (seems to have about 0.2V on the pins so resistance measurements are off but the meter reports around 30 ohms). So something's dicky. The passenger door, boot and drivers door all do this.
I've poked around at the alarm, even unplugged relays here and there but the interior light stays on. If I unplug the "Smart Entry Control" nissan module then the interior lights go out, BUT I still can't arm the alarm as it does the chirp that tells me a door is open.
Any ideas, before I call the alarm installer during the week?
chase the alarm wiring back through. most of them are found in the drivers sill on a 33. there is also a run of cable going up the A pillars. rip both off and check there.
failing that the cluster also takes the door wiring through it look there as well.
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
