I have no money and doing pizza deliveries (with another car not my line) i might have to look at selling the car so i can get more money. :(
Anyway i was hoping for a job in IT. I have my MCP in Windows 2000. I have also done about 6 months of contract work in IT. So if anyone knows of any business that even may be thinking of putting someone on, please let me know.
Also Im from perth and im willing to move to Adelaide (My hometown)
Thanks
Adam
https://www.sau.com.au/forums/topic/24177-help-i-need-a-job/
Company has a few graduate positions if your interested in moving to Syderney.
desktop engineer
automation an,alyst
helpdesk engineer
helpdesk level 1
security an,alyst
unix system admin
there's a few numbers in each category.
https://www.sau.com.au/forums/topic/24177-help-i-need-a-job/#findComment-518022
hippy,
Company is CSC (computer science corperation). I don't expect pay to be over 30k as it's a grad position.
Position is based at Chatswood for now but the company is consolidation everyone in Sydney to North Ryde in December sometime.
https://www.sau.com.au/forums/topic/24177-help-i-need-a-job/#findComment-518716
how much do you expect to get paid when your just a grad?
remember your competing with people who have loads of experience who have been out of the job since the whole .com thing went bust. Companies know their desperate and take advantage of it.
https://www.sau.com.au/forums/topic/24177-help-i-need-a-job/#findComment-519463
over here the grad pay is 42k and thats not including super ... and thats for a defence type job ... so if i were in sydney i would have to get paid at least that much cause i know how much more expensive it is in sydney .. i have friends over there makin much more than i am and they are unable to even save anything ...
https://www.sau.com.au/forums/topic/24177-help-i-need-a-job/#findComment-519466
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
