i just finnished giving mine a clean and they came up pretty clear ive tried 4 different products and the best 1 that ive used is the meguiars mirror glaze proffesional series number 17 clear plastic cleaner in a little white bottle 236ml and its the best ive used its almost got rid of all the crap on the headlights will need 2 do a little bit more 2 get it clear as im a bit drunk 2 get it done properely :P
  • Replies 46
Posted Images
I'll be able to correct those just as in the pics Daniel (Goshn) has posted.
Most R34's have this issue and most of the time it's on the outside of the lens.
I can't correct the pitting though, just the minor scratches & the faded/oxidised film on the outside, they'll be clear again.
Please make a booking on 9387 8008 and we'll have her fixed up :down:
Cheers,
d.
  SS8_Gohan said:
do a lot of country driving?
I've done a bit, they're not stone chips though. It's as though the plastic has been stressed somehow. Like miniature cracks all through it.
Email replied to Damian.
For those wondering, the Meguires PlastX stuff works a treat, i was extremely sceptical but i went down and bought a bottle of it today and an applicator pad, they came up looking like a brand new set of lights minus a few stone chips, definatly worth the $19, will post pics if anyone is interested when i get them off my phone
  • 2 months later...
ive tried plastX, scratchX & even normal polish with a orbital and its still yellowy/foggy which im pretty sure its all in the inside now. i dont want to sand the lights down just incase i ruin it so ill just get a professional to open it up and clean the insides.
any further recommendations ?
Gentlemen,
Be warned - polishishing headlights with some of the above mentioned products is doing more damage than good. A new light has a sealer that stops it from yellowing under sun exposure. You need to use a product that replaces the sealer after you polish. this way your not redoing the job every 3 months and doing more damage.
One word "Glassylite"
google it / ebay it / flickr it / youtube it.
Edited by R34GT-T
i always wax my headlights after a polish, with OCW. Has UV(b?) filters/blockers, etc... my headlights have held up fine 8 months after their last polish. But it's inevitable that they'll revert at some stage, but a 5 minute job with the RO, plus Edge green on with IP 3.01 and we're laughing again. This $100 dismantling job is a bit of a rip-off IMO
  • 3 months later...
Hey guys thought this thread might help me fix my cloudy drivers side headlight. So I bought myself some plasticX and although I removed what I could from the outside the headlight is still cloudy! Further investigation revealed that the plastic mounts on the housing have cracked and now have left a nice hole... So I am convinced that I need to clean the inside of the headlight and patch the hole. However no one has advised how to attempt this. There has been mention of removing the headlight and placing it in the oven and heating it until it is soft enough to separate, but no positive statement that anyone has done this. So my questions are:
1) How do I SAFELY open the headlight
2) Should I use plasticX on the inside or just a car wash and let it dry?
3) How to reseal the headlight.. Basically can I just reheat it until it is soft and sticky again and then clamp it shut and cool?
Cheers dudes and dudettes
Edited by chrisR34GTT
After polishing with Meguiars Plastx I always put a coating of PLEXUS on the headlights and even tail lights
http://www.plexusplasticcleaner.com/plexus.html
http://www.whitworths.com.au/main_itemdeta...tAbsolutePage=2
  • 1 month later...
I just got that Glassylite product off ebay (about $40) it comes as a kit incl. 2 different wet sand papers, a polish and the all-important sealant that's supposed to stop the issue from reoccurring... gonna try it today. Will let you know how it turns out. I have the same sort of crap like llama_au above, it looks more like stress fractures than oxidation.
Mine have actually looked pretty good since the last time I hit them with PlastX which would have been a good four months ago or so. Maybe just takes repeated use and a lot of extra force. I'm pretty weak.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
