glassylight ..didn't do jack shit for me. Still same stress fractures and it looks like stains on the inside :(
We should get someone to take a mould and make up glass lenses and do an R34 groupbuy :)
  • Replies 46
Posted Images
guys, if a "hand job" won't do it... just get it machined polish with paint polish. prep it (ie, remove polish residue) and apply any wax/sealant. it's pretty damn simple.
my car was detailed a year ago, and my headlights are still clear as day.
I'm sure a machine polish would make it look shinier as it's hard to do it by hand after wet sanding ... BUT, as I said, mine appear to be fogged/stained from the inside and the stress fractures don't appear to be on the surface at all .. so the lenses are pretty much rooted.
edit: ... unless I take the lenses off completely and do the insides ... which I need to do anyway to install the LED streips I bought :thumbsup:
Edited by Delta Force
Hey Mick who's the guy in Hornsby and can he actually remove the headlight lenses and fix it up from both sides? I need to take the lenses off anyway as mentioned above because I want to install led strips as daylight driving lights..
  • 11 months later...
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
