hey my car has the following done for handleing:=
Suspension:
Bilstein Shocks
Eibach Springs
whiteline Front and rear strut braces
Whiteline front and rear adjustable sway bars
Uras adjustable castor rods
rolling on 18x8" XHP wheels
Fronts 225/40/18
Rears 235/40/18
the reason why it handles poorley is because i had a bmw e30 with just a set of springs that handled better
do i need to fine tune it all???
https://www.sau.com.au/forums/topic/241811-why-does-my-car-handle-like-sht/
how does it handle?...
too much body roll?
no grip?
understeer?
oversteer?
poor steering feel? etc.
the e30 handles quite nicely from the factory, i almost bought one a few years back, (i presume ur talking about an e30 with an rb20 in the front),
so you may have just set the car up too stiff, but its hard to know whats wrong without you going into more detail about how the car currently handles.
too much body roll?
no grip?
understeer?
oversteer?
oops i meant my new r33 sorry guys for the confussion
i felt the bmw handled better just off a set of springs
shorter wheel base and weight makes your beamer more of a go cart to drive. 33's are abit of a whale but it seems like you have most of the gear to fine tune it. as teh post before what exactly are you experiencing that your not happy with.
I guess you just have to adjust to its handling characteristics abit.
i suggest a set of coilovers wich aint to bad in price these days...
and adjustable chamber arms for front and rear
that way u can weel align it to handle how ya want...
oh and remove the hicas so u dont get that taking over at higher speeds
do they come with a hicas bar standard??? and what happens @ high speeds when its on???
practically i want a bit of a drift car but is that possible if you want it to handle to???
well they have got hicas standard.. it it assist steering in moving the rear wheels wich can be a problem esspecially if u want a drift car..
so u have to get a hicas lock out bar. there only about 100 dollars and easy to install. if u get those mods and take it to someone
that knows how to set a wheel align up for a drift car u will have no probs with handling...
ok so basically i just need to get one of these bars to lock the wheels into place will this make it handle any better???
or is it just sweet for drifting???
No, removing the hicas will not make your car go from handling crap to great. I doubt you would even notice the difference. Hicas adjusts small amounts of toe in the rear of your car when travelling over 80kms(ish). I'm not suggesting it's a bad thing to remove your hicas but don't believe all the hype people make about how incredible you will drift after it's gone. It's simple... you won't.
Your car already has "coilovers" since that's what R33's comes with from factory and it sounds like you have a decent set in there already so don't be in a rush to take them out. Do some searching on the forums and you will find vast amounts of info to help you get the car better set-up. All I can suggest is to take it one step at a time so you know what is improving your car and what isn't.
Simple but effective: get a nice set of coilover suspenion (don't go cheap) and lower it down a bit... get good tyres (don't go cheap)... get a wheel balance/allignment... then drive it... you will notice the difference...
hmmm.... well u decide weather the hicas affects ur driving... i have never felt it in mine and i dont have the lockout bar. but for a 100bucks it aint much... obviously your car has coilover set up suspenion but they aint ajustable and will never preform as good as say tien or hks adjustable suspenion, if ya do the mods i suggested u should have no trouble..
Having suspension parts is all well and good but they are just like good stereo equipment.... if they are not set up right it is going to waist...are the shocks adjustable? and the castor arms... if they aren't right they do more harm than good in my opinon.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
