hey my car has the following done for handleing:=
Suspension:
Bilstein Shocks
Eibach Springs
whiteline Front and rear strut braces
Whiteline front and rear adjustable sway bars
Uras adjustable castor rods
rolling on 18x8" XHP wheels
Fronts 225/40/18
Rears 235/40/18
the reason why it handles poorley is because i had a bmw e30 with just a set of springs that handled better
do i need to fine tune it all???
https://www.sau.com.au/forums/topic/241811-why-does-my-car-handle-like-sht/
how does it handle?...
too much body roll?
no grip?
understeer?
oversteer?
poor steering feel? etc.
the e30 handles quite nicely from the factory, i almost bought one a few years back, (i presume ur talking about an e30 with an rb20 in the front),
so you may have just set the car up too stiff, but its hard to know whats wrong without you going into more detail about how the car currently handles.
too much body roll?
no grip?
understeer?
oversteer?
oops i meant my new r33 sorry guys for the confussion
i felt the bmw handled better just off a set of springs
shorter wheel base and weight makes your beamer more of a go cart to drive. 33's are abit of a whale but it seems like you have most of the gear to fine tune it. as teh post before what exactly are you experiencing that your not happy with.
I guess you just have to adjust to its handling characteristics abit.
i suggest a set of coilovers wich aint to bad in price these days...
and adjustable chamber arms for front and rear
that way u can weel align it to handle how ya want...
oh and remove the hicas so u dont get that taking over at higher speeds
do they come with a hicas bar standard??? and what happens @ high speeds when its on???
practically i want a bit of a drift car but is that possible if you want it to handle to???
well they have got hicas standard.. it it assist steering in moving the rear wheels wich can be a problem esspecially if u want a drift car..
so u have to get a hicas lock out bar. there only about 100 dollars and easy to install. if u get those mods and take it to someone
that knows how to set a wheel align up for a drift car u will have no probs with handling...
ok so basically i just need to get one of these bars to lock the wheels into place will this make it handle any better???
or is it just sweet for drifting???
No, removing the hicas will not make your car go from handling crap to great. I doubt you would even notice the difference. Hicas adjusts small amounts of toe in the rear of your car when travelling over 80kms(ish). I'm not suggesting it's a bad thing to remove your hicas but don't believe all the hype people make about how incredible you will drift after it's gone. It's simple... you won't.
Your car already has "coilovers" since that's what R33's comes with from factory and it sounds like you have a decent set in there already so don't be in a rush to take them out. Do some searching on the forums and you will find vast amounts of info to help you get the car better set-up. All I can suggest is to take it one step at a time so you know what is improving your car and what isn't.
Simple but effective: get a nice set of coilover suspenion (don't go cheap) and lower it down a bit... get good tyres (don't go cheap)... get a wheel balance/allignment... then drive it... you will notice the difference...
hmmm.... well u decide weather the hicas affects ur driving... i have never felt it in mine and i dont have the lockout bar. but for a 100bucks it aint much... obviously your car has coilover set up suspenion but they aint ajustable and will never preform as good as say tien or hks adjustable suspenion, if ya do the mods i suggested u should have no trouble..
Having suspension parts is all well and good but they are just like good stereo equipment.... if they are not set up right it is going to waist...are the shocks adjustable? and the castor arms... if they aren't right they do more harm than good in my opinon.
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
