for sale are a set of 4 5Zigen FN01R-C's in gloss black with the machine polished lip - also come with the genuine 5Zigen carbon fibre looking centre caps
were originally bought to put onto my S14, however were too wide so a new direction was needed
i imported these rims myself from the USA and cost me over $2000 for them landed
i am looking for a quick sale of $1800 ono
these rims have never been driven on, they did have tyres put on them but i have taken them off as ill need them for the new rims i have purchased
i have been told these are a perfect offset (17x10 +25) for a GTR or a widebodied skyline or S13/180sx...
as far as i am aware there arent too many of this type of rim in australia as 5Zigen Australia seems to be non existent here, so grab yourself an awesome set of rare rims for you pride and joy
i am located in the lower blue mountains about 10-15 mins away from penrith...this sale is pick up only
https://www.sau.com.au/forums/topic/241820-set-of-4-5zigen-fn01r-c/
are these genuine 5zigen??
the only reason i ask is because i have a set of these in mat black and they have 5zigen stamped into them not Fn01r-c.
i thought they only stamed 5zigen on them???
im not saying this is true just curious because i havent seen them like this.
if they are this is a good price brand new from 5zigen these are worth close to 3 grand.
if i didnt have some already id be interested cause they look tough as on my 33.
good luck with the sale though.
thanks mate...yeah they are genuine 5zigen bought from 5zigen international
i got them in from the usa as it was cheaper than buying them from japan due to the dollar situation when i got them...
if i had of got them from 5zigen japan i think from memory it would have cost me about $2700 so i got them from 5zigen usa and ended up costing me around $2100 landed...
Edited by R32_GTS-4
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
