hehe thanks; my last avatar was better but was borderline soft pornography so modz removed it.
And she can use chopsticks, far I'm Chinese and I still dunno how to use chopsticks correctly :)
hehe i wonder what else she can do with them; im half chinese and i won the jellybean eating contest in year 7 lolz
yeah I was looking at some really tidy R33's for around 12k, but just couldn't bring myself to get one knowing that I'd be driving a car which I hate the look of (not to mention the Skyline equivalent of the VN haha), I think maybe the market is saturated with them? Thats my guess anyway.
oh well, ain't you special :P ... narf I came 1st in maths in year 8 hehe, piss easy I tell ya
Edited by POLICE
oh well, ain't you special :laugh: ... narf I came 1st in maths in year 8 hehe, piss easy I tell ya
Well.......ummmm...oh i have a dog named milo :sick:
wow we're acting childish lolz; Whats mods u have on your car? did u pick it up stock cos i still cant believe the price u paid.
I was under the impression they were still going for 15-17k
I paid 17k for mine back in 2000
I bought mine mid Feb 2007, yes the modifications costed me around 5K
1K of which are still sitting in my garage collecting dust
and another 1K of which are either in the garbo or no longer of any use haha
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
