Im selling a garret 3082r or known as gt 3040
serial number 700177 - 5014
reason for sale is ive got it bolted up to an rb20 its just a tag laggy for my liking
nothing wrong with the turbo at all its only done 7000kms on my car so it is brand new......
more than welcome to see how it goes on my car in fact i wont take it off my car unless sold because i am going to change it for a smaller turbo.
its more suited to a rb25/ rb26 i made 260rwkw on my 2.0lt and detuned it too 240rwkw.
its capable of over 300rwkw on the right engine easily
turbo is rated at 600hp Ar .70 and im not exactly sure but i think its .82 rear
compressor is like a gt 3540 (600hp) in a gt30 cover
it has a t3 flange and suited for external wastegate
price $2100
https://www.sau.com.au/forums/topic/241834-garret-3082r-gt3040-for-sale/
Ive been rebuilding the car for the past 16 months so its now out of warenty but still pretty much brand new
i paid $2300 for it at the time
and like i said price is fricken negoitiable Capish...
i want a 3071r
but what is the gt 3037s capable of?
have you had it on an rb20?
send cash your way ??? no chance bud my turbo is brand new..... whats a 3037 worth?
ok ive decided to pull out the turbo in 2 weeks to have the new one fitted so if anyone is interested in seeing this one on the car you need to let me know asap
any offers weclome like i said price is negotiable i cant stress this much more the turbo is in perfect condition it will not dissappoint the new owner
really???
exactly the same?
the one you got quoted is probably stock off the shelf?
if they modify the turbo in any way they become more pricey
wheel sizes ect ect mine has a 3540 compressor in the gt30 cover
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
